Brake lights and turn signals
Postby Eric_M » Mon May 14, 2012 12:10 pm
I am having an issue with the rear brake lights and turn singals.
The brake pedal switch apears to be working
4 way flashers only makes the front blinkers work
Std turn signals only makes the front work.
No brake lights or turn signals in the back. Checked for voltage and nothing in the back of the truck.
Marker lights work.
I am looking for the common places to start looking. This truck also has a scotch lock infestation :( any of them I am finding are getting removed and fixed.
Or if anyone has any links or information regarding the electrical on a 91 d350 I would really apreciated it!
Thanks!
91 D350 5spd stock a little rough around the edges and needing some work but it should drag my 87 4runner around great!
Eric_M
Re: Brake lights and turn signals
Postby PToombs » Mon May 14, 2012 4:55 pm
Look up under the dash where the clutch pedal is/ could be. There is a blue rectangler plug about 2 inches long and 1/2 thick. This is the plug for the rear lights. It goes out thru a grommet near the steering column. If nothing works check this, and the ground wire in the rear.
Postby Eric_M » Mon May 14, 2012 5:53 pm
Will do! I know exactly which one you are talking about. Its been hit a few times with the clutch. I will check it out and probably redo and add a few grounds on the body and frame of the truck
Thanks!
Eric_M
Postby Eric_M » Sat May 19, 2012 2:40 pm
Ok I have a Left brake light now......
No power to the right brake light. Any ideas on where to look? Or is this a turn signal problem?
Also Fusable link stuff This is the one under the hood about a foot from the battery.
What is the middle orange wire?(2nd from the edge) and what should it be fused at? Right now mine is just running to the battery directly.....
Edit for more information. Only have power on one pin on the big blue plug by the steering column when the brake is pressed.
Eric_M
Postby PToombs » Sat May 19, 2012 5:51 pm
May be a bad multifunction (signal) switch. Try wiggling the switch and see if you get power with the brakes on. Sometimes the contacts get hot and melt down into the plastic and don't make contact.
Do the signals work? if so it's the switch for sure, because if the wires were bad they wouldn't work.
Postby Eric_M » Mon May 21, 2012 8:59 am
PToombs wrote:May be a bad multifunction (signal) switch. Try wiggling the switch and see if you get power with the brakes on. Sometimes the contacts get hot and melt down into the plastic and don't make contact.
I will give that a good try!
Anyone know of a good source for a wireing diagram? Do the Haynes or Chilton Manuels have a wireing diagram? I need something I can look at.
Eric_M
Postby CumminsPower59 » Mon May 21, 2012 10:02 am
Them el-cheapo manuals ain't got much in there for diagrams, the FSM is the way to go ;)
Postby ellis93 » Mon May 21, 2012 10:39 am
Postby Eric_M » Mon May 21, 2012 10:44 am
ellis93 wrote:should be close
viewtopic.php?f=30&t=11477
If not
viewtopic.php?f=30&t=11469&p=87501&hilit=93+wiring+diagram#p87501
Thanks! Now to figure out how to print them to take them home.... I hope those help me out, and the handfull of fuses I picked up yesterday!
I just hope I can figure it out from a not great print job!
Eric_M
Postby ellis93 » Mon May 21, 2012 10:59 am
Are you veiwing this from a computer or phone
Postby Eric_M » Mon May 21, 2012 11:18 am
ellis93 wrote:Are you veiwing this from a computer or phone
computer, saved them and printed and they are a little blury, is there a way to get better quality picture? it might be a user issue....
Eric_M
Postby CumminsPower59 » Mon May 21, 2012 12:10 pm
Postby ellis93 » Mon May 21, 2012 1:40 pm
Eric_M wrote:computer, saved them and printed and they are a little blury, is there a way to get better quality picture? it might be a user issue....
I've been told that before but I was gonna say that if you were looking on a phone you might have an option that says "view full image" and that would get it clear. On a computer,I've no idea :|
You might dig threw my photobucket account (Ellis111)
Have you access fax machine that prints clear enough to read 8)
Postby Eric_M » Mon May 21, 2012 2:04 pm
Ellis Pm inbound.
Eric_M
Postby ellis93 » Tue May 22, 2012 5:57 am
Fax sent ;) also a test is included for the MF switch itself. Find yourself a multimeter :lol: its gonna be fun.
Return to Electrical
