Brake lights and turn signals
Re: Brake lights and turn signals
Postby Eric_M » Tue May 22, 2012 8:13 am
ellis93 wrote:Fax sent ;) also a test is included for the MF switch itself. Find yourself a multimeter :lol: its gonna be fun.
Thank you! and yes I am sure it will be loads of fun.... at least I can figure out what I am looking at!
91 D350 5spd stock a little rough around the edges and needing some work but it should drag my 87 4runner around great!
Eric_M
Postby Eric_M » Thu May 24, 2012 8:29 am
Finally rounded up a good volt/ohm meter hopefully I will know by tonight if the switch is the issue.
Eric_M
Postby Eric_M » Thu May 24, 2012 7:43 pm
Well the switch fails a few of the tests. So the switch is bad.....
Anybody have the part number or a good source for the switch? or other options?
Eric_M
Postby PToombs » Fri May 25, 2012 6:08 pm
Mark! Got a sucker for ya! :lol:
Just kidding, PM Mark Nixon, he's got tons of stuff.
Postby Eric_M » Fri May 25, 2012 8:48 pm
PToombs wrote:Mark! Got a sucker for ya! :lol:
Thanks for the tip but I already ordered one.... Hopefully it will fix my problems! well the brake light and turn signal problems.
Eric_M
Postby Eric_M » Mon Jun 04, 2012 8:10 am
I figured I would say what I did to get things fixed.
I went and removed all scotch locks and soddered and repaired all the wires. Problem of no right brake light and turn singles was still there.
Put a new multi function switch in and everything is working great!
Thank you to everyone that helped me get this little problem figured out.
For those in the future that come across this problem start by checking the multi funcion switch it was much easier then taking the complete dash apart looking for issues.
Eric_M
Postby PToombs » Mon Jun 04, 2012 6:02 pm
Thanks for posting back. It's nice to know the solution to a problem in case others have the same problem. 8)
Postby ellis93 » Mon Jun 04, 2012 7:21 pm
Glad you fixed it ;)
Postby Eric_M » Mon Jun 04, 2012 9:10 pm
PToombs wrote:Thanks for posting back. It's nice to know the solution to a problem in case others have the same problem. 8)
I know exactly what you mean! I can search and find the same questions most of the time but usually there is not a verified answer or at least what worked for them posted. SO I am trying to help one problem at a time!
ellis93 wrote:Glad you fixed it ;)
You gave me the magical piece of paper that made it possible, thank you!
Eric_M
Postby PToombs » Tue Jun 05, 2012 5:18 pm
He gave you cash and paid for the part? :lol:
Return to Electrical
