Mustang Cummins
Mustang Cummins
Postby IowaCummins » Sun Jan 10, 2010 2:09 am
Alright so around here there is a bunch of 5.0s and alot of v6 mustangs running around thinking they are the fastest thing out there. well i want to prove em wrong and still have all diesels in the garage. so local craigslist found me a 79 mustang for just under $500. no rust and a few small dents, but other wise pretty straight. i have yet to purchase it. before i do i need to get some measurements under the hood. i got a buddy that has a few fox bodies, so im going to do some measureing. i am very familiar with the 1st gen cummins and the VE pump but i think i might try and find a early P pump with the 47RH so i will have easy power and a lock up convertor. the rear end im thinking will be a 9" i might try leaf springs with cal trac's or i migh just go straight to a 4 link coil over suspension. i have no clue on the front end yet. i might just have to figure out who makes some heavy springs and upgraded ball joints? maybe just air bag it and call it good. might get a small intercooler for upfront and a radiator is goign to have to be custom, along with electric fans. let me knwo what you guys think. suggestions and ideas are very welcome!
IowaCummins
Postby oldestof11 » Sun Jan 10, 2010 8:56 am
Someone on CompD put one into a Stingray with a cowl hood. Might want to go look at that.
Postby IowaCummins » Sun Jan 10, 2010 8:57 pm
yeha he is out of mitchelville iowa i think? i have read a few of his threads. he is also pretty big of heartlanddiesel, so i have seen some vids of it. its pretty nice car to say the least
IowaCummins
Postby Billy Boy » Tue Jan 12, 2010 4:11 pm
FWIW there is a 67 Camaro drag car with a common rail profiled in the February 2010 issue of Diesel World on pages 58-62.
1989 Dodge D350 Dually, Non I/C
Billy Boy
Postby peobryant » Wed Jan 13, 2010 6:57 am
I have no idea what the measurments for the 'Stang are under the hood, but I'd assume it'd be easier to get a 4bt under there. If you can find a 4bt with a P7100 on it, you can still make a lot of horsepower, and it would be lighter. Something else to think about...
Re: Mustang Cummins
Postby 1lowdiesel » Mon Apr 12, 2010 7:05 am
1950 international cummins rat rod w/ a few mods :)
1lowdiesel
Re: Mustang Cummins
Postby ahale2772 » Thu Apr 29, 2010 6:57 am
in a foxbody!! yikes u cant even fit a 351 in one of them despite a cummins! good luck!
Re: Mustang Cummins
Postby wwaaddss » Fri Jun 08, 2012 7:46 pm
if you can fit it in thatd be a badass ride
wwaaddss
Re: Mustang Cummins
Postby 4thesporty » Thu Jun 28, 2012 11:40 am
There is a guy on 4bt swaps that put a 6bt into a square body S-10, so i'm sure it can be done. Of course this guy could rest his arm on the back two valve covers :)
4thesporty
Re: Mustang Cummins
Postby VanillaGorilla » Thu Jun 28, 2012 2:09 pm
Once it fits in there you're going to go through hell trying to hook it so you have a chance with the local 2900lb v8 cars that can practically hook in dirt. . . small chance I've been around some street racing
93 Reg cab LE 4x4 518AT, 145k and counting, pump turned up,Internal pump mods, Denny T stage 2, non IC DV's, timing bumped up, BD 40hp injectors,BHAF and me-built mandrel bent CAI,4" turbo back, Holley lift pump, new white with gold paint job, recieving more mods to tow the Duster and push this stupid WI snow.
VanillaGorilla
Re: Mustang Cummins
Postby Mark Nixon » Mon Jul 02, 2012 8:56 pm
Pointless venture for street use, much less on a good track with slicks.
I used to run a very warmed up 426 Wedge in a 1970 Duster on the street.
It was nearly impossible to hook up on the street.
I can't imagine what an engine that's double that weight, in a body 2/3rds the weight of the Duster would be like to try to drive.
Don't forget, it's easy to go, but much harder to "whoah".
You'd stand a better chance of running a 4bt, at least then you'd be able to overcome the weight.
Re: Mustang Cummins
Postby PToombs » Tue Jul 03, 2012 5:57 pm
Mid mounting it should take care of the weight transfer issues. :mrgreen: I don't think I want to be sitting next to that SOB going down the track at WOT though! :lol:
Re: Mustang Cummins
Postby coltonhollenbeck » Sat Jul 07, 2012 2:33 pm
ahale2772 wrote:in a foxbody!! yikes u cant even fit a 351 in one of them despite a cummins! good luck!
On the contrary i have a buddy with a 351 Cleveland. Wasnt easy but it fits lol
coltonhollenbeck
smoke screw?
