headlight wiring where dose what go?
Postby 78fordf150ranger » Wed Jul 04, 2012 6:52 pm
Okay while I was relooming/inspecting my engine wiring harnesses I found a burn black wire that "T" off to too wires where can I find a wiring diagram/color as to where this wire goes
78fordf150ranger
Re: headlight wiring where dose what go?
Postby ellis93 » Wed Jul 04, 2012 7:12 pm
Yr model of said harness or truck
Postby 78fordf150ranger » Thu Jul 05, 2012 7:14 am
1993 dodge 250 diesel 4x4 and it the engine bay harnesses
78fordf150ranger
Postby ellis93 » Thu Jul 05, 2012 9:33 am
Postby PToombs » Thu Jul 05, 2012 4:57 pm
The headlight wires come out of the bulkhead fitting, both sides in the same terminal, 1terminal wires red/ orange for high, the other terminal violet/ white for low beam. They split in the harness just below the bulkhead and 1 goes across the firewall to the passenger light and the other goes past the battery to the drivers light.
The grounds are on the firewall near the lights. You should biggie size those because they are way too small. ;)
Postby 78fordf150ranger » Thu Jul 05, 2012 9:35 pm
So with that being said the burnt up wire (black) is more than likely the ground?
78fordf150ranger
Postby PToombs » Fri Jul 06, 2012 5:45 pm
Yup. Black is usually the ground on these trucks, but there is a black with yellow tracer that I can't remember what it's for..... :oops:
Postby bmoeller » Thu Jul 12, 2012 7:59 pm
If it has a bullet end on it, it's probably for clearance lights. ;)
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Return to Electrical
