KTA wrote:Dual feed injectors is not the same thing as dual feed to the injection pump. Dual feed injectors have 2 feed holes in the nozzle and body to the pintle, rather than just 1.
cummins king wrote:you already have the big injector lines you really think you need dual feed injectors, what you should prbaly do is change the ends of your injector lines to 2cd gen and get second gen injectors and reduce the pop pressure
