VE timing???
VE timing???
Postby hassy21 » Sat Nov 24, 2007 2:19 am
I am going to be putting in a 3200 gov. spring and remove my afc lever and I was wondering how to advance the timing on the pump? How much should I go? Is there some detailed instuctions on how to advance the timing?
1990 Dodge CTD,4wd,91 frontend conversion, Skyjacker 6" lift, 6" stacks,fuel screw 3/4 turn away from runaway,366 spring,afc delete,timing bump,piston lift pump,autometer gauges,05 Dodge wheels with 35's
http://s54.photobucket.com/albums/g118/imca21/
hassy21
Postby cummins king » Sat Nov 24, 2007 7:08 am
if you can run a jumper cable to kps silinoved
or get a set of s bent wrenches and lossen the 4 bolts and move the pump closer to the block
93 4X4 auto
cummins king
Postby CumminsPride » Sat Nov 24, 2007 8:39 am
What exactley is the timing degree that the ksb will advance?
Wade
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby ford69557ci » Sat Nov 24, 2007 9:51 am
the ksb advance is somethin i dont think you want to run all of the time. to advance the pump loosen the ip and move it an 1/8 to 1/4" towards the head mines at a quarter and seems to be good but my friends truck like the 1/8" better just depends on the truck.
ford69557ci
Postby PToombs » Sat Nov 24, 2007 12:09 pm
The KSB is about 7*. Not what you want to run all the time. I am going to wire mine to my valet switch, see what happens. ;)
Postby CumminsPride » Sat Nov 24, 2007 12:45 pm
So what aproximatley is the advance-
1st- 1/8"=
2nd-1/4"=
Wade
CumminsPride
Postby PToombs » Sun Nov 25, 2007 7:34 am
I moved mine the 1/8, timing is now at 1.65mm, not sure what this is in degrees. I don't know what it was before, but when I get a chance, I'm going to put the gauge back in, and twist the pump to see what stock was, what 1/4 is, etc. Just to get an idea how much timing is when the pump is where. I may mark several spots so I can change timing with out the gauge.
Postby CumminsPride » Sun Nov 25, 2007 8:26 am
That's kinda where I'm at with it just not too motivated about it though!
Wade
CumminsPride
