This is a must for the high RPM motors
Postby roxxx » Sun Nov 25, 2007 4:44 pm
http://www.puredieselpower.com/catalog/ ... -1408.html
I used to get this done to all my gasser big block motors
I am not sure this will fit 1 st gen block but sure would be nice
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby ford69557ci » Sun Nov 25, 2007 7:11 pm
i imagine it would fit but dont think it would be needed unless you was tryin to spin like 5k plus.
ford69557ci
Postby roxxx » Sun Nov 25, 2007 9:22 pm
yes true, but if i had my engine out i would do it just to strengthen block due to Cough all the HP we all are tryin to make :) plus if we are draggin around bigger loads it would be a bit of insurance for the price
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby ford69557ci » Sun Nov 25, 2007 10:33 pm
i am not going to run one with my ve power effort but i do have a haisley one for my p pump engine
ford69557ci
Postby seeker1056 » Mon Nov 26, 2007 5:20 am
Did you read the fine print?
"Please note: Custom Girdle pictured, actual girdle will NOT integrate the main caps into the design structure. "
Not sure what good it would be without that feature as then all it would be is a block spacer or crank spacer/baffle?
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby KTA » Mon Nov 26, 2007 6:59 am
That is a factory Cummins part, they refer to it as a block stiffener. 8)
