new injectors
new injectors
Postby gomerpile » Mon Nov 26, 2007 3:22 pm
ok so i now have some bosch 190's on their way :evil: , so heres my question. what is the exact process to changing them, i says i comes with intall kit. i am going to make this http://www.dieseltruckresource.com/dev/showthread.php?t=124728 to remove them, now what do i have to get out of the bore after i got out the injectors?(washers,gunk, etc.) any tips/tricks i need to know?
1992 Dodge D-250 LE auto, LSD w/3.54, about 200,000+ miles.Isspro Pyrometer , Sunpro tach,Tractor Supply Boost Gauge, Old Smokey Fuel Pin,4 turns on fun srew, starwheel turn CCW 1 turn, 40hp injectors, BHAF,16 cm housing.Sony Head Unit.
gomerpile
Postby 6LCummins » Mon Nov 26, 2007 3:32 pm
you will want to get the seals out and make sure u use an injector bore brush to clean up the injector holes. other than that it is pretty easy and straight forward.
Frankentruck
1988 V30 Crew Cab Long box SRW/DRW
Cummins Turbo Diesel
NV4500
600HP Full Ceramic ValAir Clutch
6LCummins
Postby PToombs » Mon Nov 26, 2007 7:40 pm
Watch the old injectors when you pull them. If the washers are on the injector, you can see it, and don't have to worry about them in the hole. I just blow some air in there to blow the crud out. A wire brush first would help.
Postby CumminsPride » Tue Nov 27, 2007 6:37 am
Before you start, I recommend some engine degreaser and a pass with the pressure washer:) !
Wade
06 3500 AT Mega Cab SRW 4X4
CumminsPride
