EXHAUST BRAKE COMPARISON
Postby DTanklage » Tue Nov 27, 2007 8:23 am
you are
lol
tubing is always measured by inside diameter
4" 16 ga tubing is 4.0 - (2x.051) or 3.898" on the i.d.
the ends of a pc of tubing (or mandrel bent u-bend) can be ordered either id or od
od od butts together where id od forms a slip joint
DTanklage
Postby Begle1 » Tue Nov 27, 2007 9:04 am
Vinyl tubing is measured by outside diameter. Rubber hoses are inside diameter. Pipe is inside diameter.
Postby flashgordon » Tue Nov 27, 2007 10:01 am
Begle1 wrote:Vinyl tubing is measured by outside diameter. Rubber hoses are inside diameter. Pipe is inside diameter.
So did you ever by any Vinyl tubing?
Flash.
flashgordon
Postby DTanklage » Tue Nov 27, 2007 10:36 am
i heard beagle is really into vinyl and spandex
lol
jk
DTanklage
Postby ford69557ci » Tue Nov 27, 2007 5:39 pm
i have the same one that you have except it was bolted right to the turbo and was made for a c7 cat in a motorhome
ford69557ci
Postby DTanklage » Tue Nov 27, 2007 10:44 pm
bolted right to what turbo?
this one i have take a odd ball v-band clamp
DTanklage
Postby Stomp » Wed Nov 28, 2007 12:17 pm
DTanklage wrote: PAC BRAKE SUCKS
the purpose of this thread is to worn others (that are into high hp ve trucks) not to get sucked into buying a pac brake
You kind of jump to conclusions awful fast don’t you? I had a turbo mount Pac on my pickup for 4-5 years before I put twins on. I used it with my stock H1C and then I had an adaptor plate on the back of my HX40 so I could still use it. So I went from 4” off the back of my HX40 to 3”. The brake worked awesome and I never had any problems with it. I made 440hp on #2 and 530hp with the help of water/meth. Was it restrictive yeah, but it worked. I still got 20mpg on the highway and 16 in town and running up and down the mountains.
I just have one question for you. Did you ask Pac Brake the inside diameter before you bought it? No you probably assumed that it would be 4” id. I think we all know what ASSUME means?
Just for kicks maybe you should do some testing before opening you mouth too far. Test both of them and then report back. Don’t bash one without even trying it. I have heard that Pac Brake works better on Cummins than a BD does and BD works better on a Powerstroke than a Pac Brake does. On a Duramax it was about a toss up. This was from a reliable source that had done some testing with both products.
Stomp
Stomp
Postby ford69557ci » Wed Nov 28, 2007 1:30 pm
sorry don i meant clamped i have never tried it out but i know people with them on motorhomes and they say it works great. hey if you want to stop without usin your service brakes i have this big goofy electronic hill brake from a goshen bus. It mounts inline of the drive live and has two bigass dish with like 20 little brake pads i think its called a tilmer brake? i know if you nail it at 60 the bus will almost fly off the road lol.
ford69557ci
Postby DTanklage » Thu Nov 29, 2007 10:27 pm
jeremy, i didnt assume anything
the brake is not 4" and it is restrictive, just like you said it is
i spent a lot of time and money building a down pipe that will flow (as in you can roll a 3.900 ball thru it) and that is why i want a 4" brake
tj saw this thread and contacted me yesterday, he said he is going to see what he can do
don
ps - this is not my first brake jeremy. this is my 4th. one of them i didnt try (4" bd) and the other two were both pac clamp to the turbo style units. one of them worked better than the other but they both worked very well. i didnt care about flow then but i do now
DTanklage
Postby DTanklage » Thu Nov 29, 2007 10:47 pm
Stomp
no, i asked them for a 4" brake
if someone asks me to build them a 1/4 stroker and i ship them a 1/8th inch stroker they are gonna be pissed
if i advertise a .700" lift cam but ship a .600 cam they are gonna be pissed
if i bought a 4" ex system and it was made out of 3.5" tubing - i would be pissed
DTanklage
Postby flashgordon » Sun Dec 02, 2007 10:05 pm
Been working on my intercooler project and desided to take a couple of pic's while i had the turbo off.
http://i125.photobucket.com/albums/p58/ ... C01893.jpg
http://i125.photobucket.com/albums/p58/ ... C01894.jpg
I thought our outlets were 3" :sad:
http://i125.photobucket.com/albums/p58/ ... C01895.jpg
Flash.
flashgordon
Postby DTanklage » Mon Dec 03, 2007 9:08 am
that is what i was saying in my tdr thread - no need to step right up to 4" if you are running a stock turbo
for drag racing we use stepped ex
for optimum flow the i.d. of the tubing would increase at 4° increments
but using those numbers it would be 2.5" at the turbo and over 6" behind the tire
one thing is for certain - the hot ex gases are expanding so you dont want to neck it down anywheres down stream
DTanklage
Postby DTanklage » Mon Dec 03, 2007 9:47 am
ps - i am not running a stock turbo
that housing is 4" i.d. at the outlet
DTanklage
Postby ford69557ci » Mon Dec 03, 2007 7:51 pm
damn don that thing is way to clean i think you need to put that on your truck :thumleft:
ford69557ci
Postby DTanklage » Mon Dec 03, 2007 9:02 pm
that turbo's on there
been on there for months
the ex system isnt finished tho...
still waiting to hear back from pac
got smoked tonight
dont know if it was gasser or duramutt but he pulled me for a split second then got off the frwy
my dumb ass was cruisin along in 5th over @ 1500 w/o the ksb activated when he pulled up on the right of me and nailed it
i rolled into it (fogged the guy behind me), hit the spliter switch, but straight 5th was still too tall and it didnt go anywheres
hate it when that happens...
ESPECIALLY NEXT TO A CHEVY
DTanklage
