God loves me, still
God loves me, still
Postby mhuppertz » Thu Jan 11, 2007 8:37 pm
So, I have been living with a frosty cab because it's better than blocking off the radiator and loosing the benefit of the intercooler, but yesterday, bling! I had heat. The temp needle moved up to it's normal position! I have had good cab heat since then.... I guess the thermostat was never closing all the way THE WHOLE TIME I HAVE OWNED THE TRUCK! It always worked fine when it was warmer, and when I would block it off the temp would eventually come up to normal after it got a little warmer. I just assumed it was a diesel thing. I actually had to turn the heat DOWN this morning!!!
mhuppertz
Postby 92 D/UNIT » Thu Jan 11, 2007 9:40 pm
so did you put a new thermostat in?
388/886
92 D/UNIT
Postby mhuppertz » Fri Jan 12, 2007 6:12 am
No, the old one just started closing all the way. I will put a new one in though eventually..
mhuppertz
Postby PToombs » Sat Jan 13, 2007 3:35 pm
I can't believe you need heat in NM! What did it do, drop to 70*? :o
Postby mhuppertz » Sat Jan 13, 2007 6:10 pm
PToombs wrote:I can't believe you need heat in NM! What did it do, drop to 70*? :o
I'm at 7,000 ft elevation, and we recently had 3' of snow on the ground. It's been well below zero many times already. We haven't seen 70* in a long time!
mhuppertz
