Injector tester
Injector tester
Postby ellis93 » Mon Sep 03, 2012 9:08 am
Look and see what you guys think,BC you bought one similar,how'd it work out.
Check out this item I found on eBay:
End time: Sep 6, 2012 5:58:31 AM
Item: Diesel Injector Nozzle Tester / Pop Pressure Tester - Dual Scale BAR / PSI Gauge
URL: http://pages.ebay.com/link/?nav=item.vi ... 0774405310
Alt URL: http://www.ebay.com/itm/Diesel-Injector ... 0774405310
(Sent from eBay Mobile for Android)
Re: Injector tester
Postby ellis93 » Tue Sep 04, 2012 10:19 am
WTF guys you all don't even have an opinion :lol:
I could at least have Mr Pete come in with a wise crack! :mrgreen:
I'm gonna build on out of a bottle jack anyhow, ran across an old link off of a google search,looked simple enough to do. Half way done with it after about 2hrs of part scrounging in a bucket of fittings I have. I'll post up some pics and do alittle how to when I'm done.
Re: Injector tester
Postby PToombs » Tue Sep 04, 2012 5:03 pm
OK butthead, here's my opinion. Did you do a search? somebody on here posted a link to that same unit a while back, I don't know what the outcome was. I do remember they were nervous about buying some POS from India. :P
Re: Injector tester
Postby dazedandconfused » Tue Sep 04, 2012 5:22 pm
Re: Injector tester
Postby ellis93 » Tue Sep 04, 2012 5:52 pm
PToombs wrote:OK butthead, here's my opinion. Did you do a search? somebody on here posted a link to that same unit a while back, I don't know what the outcome was. I do remember they were nervous about buying some POS from India. :P
I read BC's post and remembered it before this,thank you very much :P
I was kinda interested in his thoughts of the tool after he's used it a few times,well.....if he's used it any. Doesn't matter now anyhow as I've already disrupted and mangled up a bottle jack
Welded on a reducer where the ram used to run thru the top
Then welded up the safety feature
Then made me a stand pipe with a tank
And bought a 25$ gauge
So I good to go so far,I've tried it out to see if it makes pressure and found lots of pin holes in my welds. Had to disassemble to fix that and I need to find a line to use to connect the injector
Re: Injector tester
Postby dazedandconfused » Tue Sep 04, 2012 6:08 pm
Where did you find the write up on how to build one?
Re: Injector tester
Postby ellis93 » Tue Sep 04, 2012 6:15 pm
Re: Injector tester
Postby dazedandconfused » Tue Sep 04, 2012 6:28 pm
Cool looks like i have a new project.
Re: Injector tester
Postby BC847 » Tue Sep 04, 2012 6:29 pm
Oops.
The one I got works just fine. The stick in the mud then was coming across an assortment of shims to adjust the pop-pressures as needed. I got very lucky and had someone from CompD send me an assortment. When I was complete, I had to send the assortment back.
I dicked with mine enough that they ended up within 5 bar of one another (IIRC). One or two took three or four adjustments, the other, eight or ten times.
Re: Injector tester
Postby ellis93 » Tue Sep 04, 2012 6:37 pm
Thanks BC ;)
And you did mean valve shims right.
Re: Injector tester
Postby BC847 » Tue Sep 04, 2012 6:40 pm
Injector shim, valve shim . . . . . . little thin roundy stickuminthespringy thingy . . . . z
Re: Injector tester
Postby ellis93 » Tue Sep 04, 2012 7:14 pm
They're bought 8)
Re: Injector tester
Postby ellis93 » Wed Sep 05, 2012 10:04 am
It's alive 8)
Tried it out and this is the numbers I came up with:
Bad numbers
Re: Injector tester
Postby ellis93 » Mon Sep 10, 2012 9:26 am
[quote="BC847"].
I have since lernt, we can use KTM motorcycle toaster shims just as well. We want the 8.9mm ones. http://www.ebay.com/sch/i.html?_nkw=ktm+shim+kit (You're welcome)
Well......this is turning out to be wrong
Those 8.9mm shims are way to big,51$ lesson learned
Reckon washers will work out?
For future reference
Re: Injector tester
Postby DodgeFreak » Tue Sep 11, 2012 6:26 am
Return to Shop
