Where do these go?!?
Postby m880cummins » Fri Sep 07, 2012 7:24 pm
These are some plugs on my '92 dash....
Behind the message center:
Under the dash by the ashtray:
My cargo light, dome light and radio don't work could this be why?
Thanks
Charlie
SUNY Maritime Class of 2017!
m880cummins
Re: Where do these go?!?
Postby CumminsPower59 » Fri Sep 07, 2012 7:46 pm
Bottom one in the first pic is for the radio IIRC...
Not sure on the others...
Postby m880cummins » Fri Sep 07, 2012 8:23 pm
yeah there's 2 for the radio in the gaping hole below the HVAC control. This 3 wired one puzzles me though just like the white one. The white one was definitely used at one point and looks pretty important.
Charlie
m880cummins
Postby little doug » Fri Sep 07, 2012 10:34 pm
That white one looks like it is for the buzzer.Not that important if your brain is still working well. :? :( :lol:
93 W250 LE extra cab, 5 speed,warn winch, tach,piro,boost gauges. Gov.spring and fuel pin... Play truck
-91 W350 LE reg cab chassis.exxxxtended 175"wb, banks intercooler,on board air ,5 speed,... Work truck
little doug
Postby cmann250 » Sat Sep 08, 2012 4:35 am
I have a white connector about that size floating around under my dash too. Never plugged in and everything works, so I just let it go
Postby bmoeller » Sun Sep 09, 2012 5:17 pm
If you don't have delay wipers, the big one could be for the timer module.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby 91bluecummins » Mon Sep 10, 2012 10:12 am
top one may go to the dash light above the message center
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Postby azsnow » Wed Sep 12, 2012 11:23 pm
The top one connects to the back of the HVAC control unit.
azsnow
Return to Electrical
