by cumminz90 » Wed Sep 26, 2012 7:26 pm
http://www.autobodyspecialt.com/cgi-bin ... &key=D-28RI'm going to try out a set of these smoked ones when i get my truck to the paint stage they look good to me.
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
