installing ip problem
Postby revemup15 » Mon Aug 13, 2012 6:30 am
Ive took ips off and one quite a few times.... well yesterday i fought then damn thing for hours.... when i stick the ip on i can only get a couple threads in screwing the nut on and i tightin it more and more getting harder each time ... i knew somthing was wrong so i take it off and the keyway is all chewed up... so I put another keyway on.... same problem... so i thought since i was installing a different ip maybe something was different... put old one on slid right on like normal.... now tried the new one.... nothin... i know the keyway is getting 1/4 or 1/2 wayin in the gear..now i cant get either one on... ive took off and installed ips a dozen times and never had a problem they have always slid right on... has anyone else has had this problem?
94 p-pump
revemup15
Banned
Re: installing ip problem
Postby directinjktn1stgen » Tue Sep 18, 2012 3:46 pm
have u tried to measure the diameter of your shafts maybe one is larger than the other ? im sure these IP are made for several othger applications depending where u got it some Joe Smoe could of messed up just a try what could it hurt right ;-)
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
Postby revemup15 » Thu Sep 20, 2012 9:15 am
Next day i got it on in 30 seconds idk what the deal was
94 p-pump
revemup15
Banned
Postby directinjktn1stgen » Thu Sep 20, 2012 3:23 pm
huh maybe u werent holding ur mouth right :lol:
Jeffery
directinjktn1stgen
Postby revemup15 » Thu Sep 20, 2012 8:00 pm
My girlfriend claims i was p.m.s ing
94 p-pump
revemup15
Banned
