by Deathrod » Mon Sep 24, 2012 7:50 pm
Timing case I might be a little worried about....if its just the cover as long as it does leak I wouldn't be to concerned about it depending on how big the jb weld fix is. I'd at least take to cover off check what's going on inside....only way to know if kdp is fixed is to see for yourself.
