draginmopars wrote:pic 3 rod on left
pic4 rod on right
looks like they have been hot/ spun bearing
oldestof11 wrote:Could it be that little dowel pin right above the vacuum pump that engages the cam gear has gotten stuck?
PToombs wrote:oldestof11 wrote:Could it be that little dowel pin right above the vacuum pump that engages the cam gear has gotten stuck?
You do realize that dowel is plastic right? It's made that way so it breaks and doesn't ruin anything when you forget and leave it in.
And you were doing so well too.............
