Project "86bt" Chevy Cummins Swap
Re: Project "86bt" Chevy Cummins Swap
Postby bighroder » Sat Sep 01, 2012 9:15 am
cmann250 wrote:The dually was 2wd
Touche'
86 suburban/pickup conversion project "Dont Even Matter"
Dana 60, 14bff, 12v ve, nv4500, np205
http://1stgen.org/viewtopic.php?f=32&t=13252
bighroder
Postby Hardluck » Mon Oct 29, 2012 8:25 am
Hey swap looks great, but I did see something that I learned the hard way. I installed dual shocks on the front of a 3500 Chevy just like you have done. The ride was improved, however when I turned the wheel all the way the outside shock bolt hit the brake caliper forcing all the fluid out. This becomes a problem when you hit the brakes and the pedal goes to the floor. Not an expert but didn't wont to see a nice truck with a boogered up grill. Mine was a Dana 60 with a bigger caliper this may make a difference but just check it out. By the way I have no idea what I'm doing this is my first post.
Hardluck
smoke screw?
Postby T_wilson_3 » Thu Nov 01, 2012 6:09 am
Hardluck wrote:Hey swap looks great, but I did see something that I learned the hard way. I installed dual shocks on the front of a 3500 Chevy just like you have done. The ride was improved, however when I turned the wheel all the way the outside shock bolt hit the brake caliper forcing all the fluid out. This becomes a problem when you hit the brakes and the pedal goes to the floor. Not an expert but didn't wont to see a nice truck with a boogered up grill. Mine was a Dana 60 with a bigger caliper this may make a difference but just check it out. By the way I have no idea what I'm doing this is my first post.
That'd be pretty scary! But ya I turned the wheels all the way each way and there is clearance enough for the shocks .Thanks though!
Tory
:grin: head
86 Chevy 4wd cummins swap in the making
91 D350 dd/donor stock
T_wilson_3
Postby T_wilson_3 » Thu Nov 01, 2012 6:14 am
Well it has been a while since I have worked on the truck.. Life has kind of been in the way lately. I am picking my transmission up this weekend though! Hope to get it in soon! I have had the chance to fab up the core support to fit the intercooler and radiator. I plan on running ac but for now I just want to get it running so I can at least drive it and work on the small things a little at a time. I have the fuel filters and pump mounted just have to run the fuel line. The bed is mounted and the toolbox/tank combo are mounted too. I'll try to get some pictures up tonight sometime.
Tory
:grin: head
T_wilson_3
Postby T_wilson_3 » Thu Nov 01, 2012 6:15 am
bighroder wrote:I don't mean to give you rif but you should have swapped the dana 44 for the 60 in that dually your ball joints are gunns take a beating
I wish I had a dana 60! That will be an upgrade for the future.. I looked for a while but cant seem to find one for less than a grand...
Tory
:grin: head
T_wilson_3
Postby Hardluck » Fri Nov 02, 2012 4:59 am
Thats good new on the shocks, it will give u a better ride. Until u can find a 60 I wouldn't worry about the 44. As long as ur not bahaing it it will hold up. I've had a couple 44s, one held a 396 on 40's and one with a 6.2 diesel(that was a stock chevy opt in 82). Never had probles with balljoints and I was pretty rough on those trucks. I would be more cocerned with the added torque and taller tires than the joints. Looks great keep up the hard work!
Hardluck
smoke screw?
Postby T_wilson_3 » Fri Nov 16, 2012 4:44 pm
The stock intake horn isnt going to work.. Im going to try a second gen's a buddy let me borrow to see if it fits...
Still have to plumb the fuel system.
Im going to try to get my transmission in it this weekend.. hopefully. Then it'll just be little odds and ends to get it running.
Tory
:grin: head
T_wilson_3
Postby dazedandconfused » Fri Nov 16, 2012 4:50 pm
Looks good.
Postby T_wilson_3 » Fri Nov 16, 2012 5:05 pm
Thanks!
Tory
:grin: head
T_wilson_3
Postby bighroder » Fri Nov 16, 2012 7:04 pm
Honestly a grand is a good deal anymore I searched and searched found a dually d60 thought oh yeah cheap 650$ set of used hubs 200$ new bearings and races 100$ yeah its ads up quick, but hey live and learn....diggin the wheels
bighroder
Postby T_wilson_3 » Fri Nov 16, 2012 7:15 pm
Ya I plan on in the future replacing the 44 with a 60 and the getrag with a nv4500. I planned on doing it to begin with, then again I planned on doing a lot of things different but for now I want to get it running and driving and upgrade stuff down the road.
Tory
:grin: head
T_wilson_3
Postby 1STGENFARMBOY » Fri Nov 23, 2012 11:54 am
don't you dare let that g-rag go without talkin to me first....... ;)
Postby CUMMINSDODGEMAN3 » Fri Dec 14, 2012 10:19 am
Get one of the industrial intake that point towards the front and weld a 90 on it...
Team Green's old hauler 05 3500 CTD 4x4 6sp 8in rize industries lift, 37 Toyo M/T's, Smarty, Edge Att, AFE intake, ATS manifold Borg Warner turbo, 5in SS MBRP
90 W350 CTD SRW big pump, big turbo, lots of fuel, 47RH billet suncoast triple disc and 20's
93 D250 CTD ext cab pump work, POD's
CUMMINSDODGEMAN3
Postby 1STGENFARMBOY » Mon Dec 17, 2012 3:32 pm
Did you ever get that clutch fork ? ? ? ? that was " shiped weeks ago "
you may need to find another place to get parts. :shock:
Postby CumminsPower59 » Tue Dec 18, 2012 7:10 am
Sooo...what did you do with the donor???
