Was lucky last night . . .
Re: Was lucky last night . . .
Postby RCCUMMINS89 » Wed Oct 31, 2012 8:28 pm
Oh, also..... I have been told by someone who works with him, that the guy that did my nozzles, also does BD's injectors. I also had a wink and bump, bump that he does the "overflow" work of ddp.
Of course the above doesn't mean a thing, and is merely here-say.
Postby BC847 » Thu Nov 01, 2012 6:00 pm
soggy wrote:I went with SDX 5x18's and they are doing well. However I don't really think SDX is an option for many people any more, I happened to get mine right before the bad things happened.'
edit. I should say that I went with the 5x18's after my scheid 6x16's did the same thing your's did.
Scheid now offers a "Billet Steel" 5x18. Flows a little more than the 6x16. To help address cracking and such, it's built around a 9mm shank so you'll have to drill out your existing 7mm injector bores. . . . .. . . if you're into it. :shock:
RCCUMMINS89 wrote:I also consider the injector builders to be very similar to an injection pump shop. Yes, there are rights and wrongs.... There are better and worse ways of tuning. But every one thinks that anybody that doesn't do it exactly like them are a worthless, retarded, doo doo head that doesn't deserve to breathe.
Ain't that the truth.
I've asked Joe to include a handful of assorted shims so I can dial-in the pop-pressure on these new nozzles. Hope to have things running a little closer to normal come Wednesday or so.
Then get back to the IP timing thing. :roll:
Postby RCCUMMINS89 » Thu Nov 01, 2012 6:53 pm
Yep, good ol' timing.... I wish it were like the old days where ya bump it and it drives better so it must be perfect. Now it's chase here, chase there....think I got it, no maybe not, maybe I should try here.
Postby oldestof11 » Thu Nov 01, 2012 8:32 pm
I don't go for "billet" injectors. Why? They are billet to start with.
Postby BC847 » Thu Nov 01, 2012 9:12 pm
oldestof11 wrote:Why? They are billet to start with.
Shhhhhhush! The people don't need to know that.
But seriously, Joe talks like there's additional meat around the sac as well. I just wasn't into $300 a piece. Or drilling into the head.
I'm sure they're good stuff but I'll take my chances with what's worked well for me. :)
Postby Tacoclaw » Fri Nov 02, 2012 5:15 am
Not that I have the slightest clue, but do you think the fact that it was a 6-hole injector contributed to this? Since there's an even number of holes it may make it easier to break like that since it can get a nice, straight shot across the tip. You think a 5-holer may be a little tougher since it wouldn't have such an easy choice to break?
Postby BC847 » Thu Nov 08, 2012 5:35 pm
^^ Dunno.
I've got one more injector's pop-pressure to set . . . . . . ugg. :?
Postby RCCUMMINS89 » Fri Nov 09, 2012 3:47 pm
get 'er done yet?
Postby BC847 » Fri Nov 09, 2012 5:13 pm
Yeah. Runs OK I guess. Certainly a lot smoother as one or two of the injectors pulled had pop-pressures well off of the original 235bar setting.
Everything's now at 240bar. I raised it 5bar in the hopes of clearing up some of the idle haze.
At this point, I've got to be careful messing with the truck as I've GOT to have it in good running order as I start a new job this coming Wednesday. I'm suppose to end up with a job provided vehicle, but in the mean time . . . .
I reckon I'll resume dicking with the IP and its internal timing this weekend. :roll:
Postby RCCUMMINS89 » Fri Nov 09, 2012 6:51 pm
Why did you decide to run the pop pressures lower than stock? To gain more fuel?
Postby BC847 » Fri Nov 09, 2012 9:10 pm
RCCUMMINS89 wrote:Why did you decide to run the pop pressures lower than stock? To gain more fuel?
Yes. :)
Postby RCCUMMINS89 » Fri Nov 09, 2012 9:55 pm
Sneaky sneaky..... smoky smoky
Postby BC847 » Sat Nov 10, 2012 2:59 pm
RCCUMMINS89 wrote:Sneaky sneaky..... smoky smoky
With the right air, it doesn't smoke any worse than otherwise. It does however contribute to idle haze. ;)
Note WOT smoke and lack of blackness (is that a word?) . . . . http://www.youtube.com/watch?v=MFlg83WExVI
A side effect is that the injection event footprint is widened somewhat which is actually counter to making efficient power IMO. :?
Postby BC847 » Sat Oct 05, 2013 7:23 am
Crap. :shock:
Postby ellis93 » Sat Oct 05, 2013 7:57 am
