BC847 wrote:You haven't said what you're going to do with the truck.![]()
I've run an HX35/Hybrid with a waste-gated 14 exhaust housing over an HT3B with a 21cm housing (IIRC). The voices in my head concur that with those turbos, the older DDP4 injectors were at the top of acceptable fuel, meaning, wound-up @ WOT, the exhaust was NOT heavy-black, . . . perhaps dark-grey. It's all muddied by the fact I also ran a slightly better than stock IC and fancy intake feed-horn. EGTs were well past 1450*F at the top of the eighth with a little 50/50 W/M.![]()
The above was observed at the drag-strip. It's been a while. I'd have to dig it up over at the DTR.
Sooo . . . . .. what'cha doin with the truck? Weekday grocery-getter / weekend warrior? Required work-truck / county fair puller? etc . . . . . .
