Timing questions
Re: Timing questions
Postby Sutter1stgen » Wed Dec 05, 2012 6:56 pm
Thanks. I was always curious about your setup. I may update my setup. I can hit 1500 degrees wih my primary right around 32-34 psi. With about 54 psi max. I'd like to cool my egts as much as possible, to better use all the fuel.
Eric
Sutter1stgen
Postby AHineman » Wed Dec 05, 2012 7:07 pm
I'm really satisfied with my setup for now. I just need some time and money to finish my dually conversion and get it painted.
Then I'd love to get a better intercooler and an aluminum radiator. It's always something I guess. :lol:
Postby cummins12club » Wed Dec 05, 2012 8:34 pm
So my IC truck would be 12 degrees stock?
cummins12club
Postby AHineman » Wed Dec 05, 2012 8:36 pm
I thought it was 12.5 degrees.
Postby cummins12club » Wed Dec 05, 2012 8:42 pm
So I'm at 18* timing roughly I just have the pump to the head how much timing should I run w the 5x18s?
cummins12club
Postby AHineman » Wed Dec 05, 2012 8:45 pm
I'd skip a tooth and the play around with it to dial it in.
Postby cummins12club » Thu Dec 06, 2012 6:06 am
Hmmm I really don't wanna go through all that work to jump a tooth can I run a dynamic timing device and see what that gets me? Somebody said on here they think that gives u 10* I don't know if I believe all that how will I know when I get the timing right?
cummins12club
Postby AHineman » Thu Dec 06, 2012 6:56 am
You'll just have to mess with it and see how you like it. 8)
Postby Sutter1stgen » Thu Dec 06, 2012 7:37 am
cummins12club wrote:Hmmm I really don't wanna go through all that work to jump a tooth can I run a dynamic timing device and see what that gets me? Somebody said on here they think that gives u 10* I don't know if I believe all that how will I know when I get the timing right?
I tried doing this same thing earlier this year. I made a fool of myself on the dyno. I only made 18hp more than my 5x12s. And I didn't have the spacer with my ddp3 ether. It's best to have a buddy as mechanically savvy as you come over and lend a hand and bust it out in 2 hours. Don't cut corners like I did, you won't be happy with the results.
Eric
Sutter1stgen
Postby cummins12club » Thu Dec 06, 2012 7:46 am
Ok so what degrees should I be runing w 5x18s like 21 degrees?
cummins12club
Postby cummins12club » Thu Dec 06, 2012 8:01 am
I just got off the phone w Schied and they told me to run 18 degrees timing w those injectors I told them I've got my pump to the head and they said I should be almost dead on 18 degrees
cummins12club
Postby RCCUMMINS89 » Thu Dec 06, 2012 8:43 am
For best results, skip that thing a tooth. Then add the timing spacer and start at the factory marks. Skipped a tooth and retarded about an 1/8" puts you at about the same thing as to the head.
Ahineman, Sutter1stgen, BC847, Bgilbert, KTA, JQmile, myself, and more.... all have run a tooth advanced for a reason
P.S. my injectors are not even close to the size that you will be running or wht the others run... I still run the best with that much timing.
Postby Sutter1stgen » Thu Dec 06, 2012 9:04 am
I was at 21 degrees on the dyno at ponci's. That's when I knew I needed more. 27 degrees seems to be the most you'd want to run from what I've researched, and been told. Plenty of people have made power without a timing light, by trial and error. Just take your time and bump it alittle at a time till you find the sweet spot.
Eric
Sutter1stgen
Postby 1STGENFARMBOY » Thu Dec 06, 2012 1:57 pm
this thread is very very informative, thanks men.
Dar
Postby cummins12club » Thu Dec 06, 2012 3:20 pm
I guess I will have to play around w it looks like ill be skipping a tooth
cummins12club
