JAyers wrote:Scheid diesel extravaganza
422hp/834ft lbs at 38psi. #2 Only.
93 250 4x4, 5speed, Autometer Pyro, Tach, & boost, 7in miter, pump maxed, SPS62, BIG edm's or DDP 3's, 3200 gsk, ASA intake, Lots of head work, Studs, piston lift pump, H2 Cam.
cody 85 wrote:312HP pump tweaked, M&H timing spacer, ground fuel pin, stock air box, stock exhaust no muffler. 91 none intercooled. Stock turbo ex housing.
i was really surprised to see that number.
BC847 wrote:You do realize that JAyers made that post on: Sun Aug 26, 2007?
http://1stgen.org/viewtopic.php?f=25&t=961&p=6981#p6981
JBradley500 wrote:yep i went friday from about 10-5... i saw FourSpeedSteve then i saw Tim Worline and Bill Gilbert camping but didnt see you or anyone else.
