radio install
radio install
Postby cummins32 » Wed Dec 12, 2012 9:16 pm
So, I bought a radio and spliced all the right wires together, but with the new speakers I got it won't play any sound through them, I ran new speaker wire, all the speakers do is make a tick tick tick noise. I've switched the wires around on the speakers and rewired it multiple times any ideas ?
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Re: radio install
Postby skilletky » Thu Dec 13, 2012 8:25 am
did you use a harness to go from the radio to the truck harness, or did you cut the plugs from the truck and hard wire it? what kinda radio?
skilletky
Re: radio install
Postby cummins32 » Thu Dec 13, 2012 9:54 am
It's an xo vision radio and I hardwired it
cummins32
Re: radio install
Postby skilletky » Thu Dec 13, 2012 11:11 am
if you ran new speaker wires and it still does it, then you may have a bad radio or just a wire crossed somewhere. or you could have a bad speaker shorting all the others out.
skilletky
Re: radio install
Postby cummins32 » Thu Dec 13, 2012 12:07 pm
Speakers are new and I tried a spare speaker and it still does it, I'm starting to think it's a bad radio, Thanks for the help
cummins32
Re: radio install
Postby 88Centurion » Thu Dec 13, 2012 4:24 pm
make sure the antenna is hooked up good. I had one one time that wouldnt play because of that. just a thought.
88Centurion
Return to Electrical
