What kind or horsepower will it make?
Postby cummins12club » Thu Dec 06, 2012 6:12 am
How much power do u guys think my set up will make? 93 IC Ve pump maxed out 4k gov spring Denny t stage 2 fuel pin non IC custom full cut delivery valves stock lines 5x18 injectors air dog 150 port polished and ceramic coated exhaust manifold 57mm hx35 over 76mm ht3b tranni is a tight automatic what kind of power am I looking at?
cummins12club
Re: What kind or horsepower will it make?
Postby Tacoclaw » Thu Dec 06, 2012 7:23 am
Mid 4's I would think. Maybe high 4's, but I always assume the worst with a non-lockup auto.
[lit fuse] It also depends on the dyno [/lit fuse]
:mrgreen:
Postby cummins12club » Thu Dec 06, 2012 7:31 am
True true I'd be very happy w a solid 450hp
cummins12club
Postby Tacoclaw » Thu Dec 06, 2012 8:34 am
I do think I'm being a bit optimistic, but you should be around 400. The 450 barrier is actually somewhat tough to break I these trucks.
Postby 1STGENFARMBOY » Thu Dec 06, 2012 1:32 pm
BC is in the mid 400's and he has a ton of trans mods along with many many more engine mods.
now if you squirt something in it, then maybe.
Postby cummins12club » Thu Dec 06, 2012 1:39 pm
Bc makes 488 last time a checked had the same turbo set up nd out injectors are very similar the only difference between my engine and his is a Hamilton cam his trans has a good converter clutches and valve body so obviously I'm gunna loose a little their but it should be upwards of 400
cummins12club
Postby AHineman » Thu Dec 06, 2012 2:07 pm
He has a better intercooler, better secondary, and a ported head as well. Not to mention water and meth injection.
Postby cummins12club » Thu Dec 06, 2012 3:15 pm
How much does an intercooler really help?
cummins12club
Postby AHineman » Thu Dec 06, 2012 3:20 pm
As for a rwhp number, IDK. Makes for lower egts, denser air, and lets you stay in the fuel longer.
All depends on what you want to do with it really.
Also, you may make you hp goal really easy, but more than likely you'll see how bad the non lockup autos suck power like most others who've run them.
Postby cummins12club » Thu Dec 06, 2012 4:37 pm
Well after these injectors and fuel system I will save for a 47re or rh
cummins12club
Postby dunes450r » Mon Dec 10, 2012 5:56 pm
i betting right around 400, maybe a little over, if its tuned correctly. when are you dynoing?
dunes450r
Postby cummins12club » Thu Dec 13, 2012 10:40 am
Probably gunna dyno late winter or early spring at thoroughbred diesel
cummins12club
Postby skilletky » Thu Dec 13, 2012 10:48 am
cummins12club wrote:Probably gunna dyno late winter or early spring at thoroughbred diesel
they are down off I64 aint they? i wanna dyno mine too but didnt know anywhere that had a dyno close. i tried modular depot when they were by the mall, but they never would let me.
skilletky
Postby cummins12club » Thu Dec 13, 2012 8:51 pm
I believe they are south of Louisville I know u take 71 for a good whole then I believe I jump on the jean Schneider freeway and its off it idk the number and I'm not 100 percent sure that's what it's called lol I dynod at Schied this past year nothing special wasn't happy w their dyno either
cummins12club
Return to Competition
