How many CC of fuel do our VE's flow?
Re: How many CC of fuel do our VE's flow?
Postby cummins12club » Wed Dec 19, 2012 9:17 pm
RCCUMMINS89 wrote:Most definitely. Anything to help burn the fuel at low rpm. With your set up and injectors study BC847....
I've been following David since I saw him on diesel bombers long before I knew of this site are trucks are almost identical and we run a very similar set up his fastest time was 12.67 I'd love to break into the 12s one day I thought he was running a bigger Hamilton like a 181/220 cam?
cummins12club
Postby RCCUMMINS89 » Wed Dec 19, 2012 9:34 pm
He just swapped cams a few months back, it helped move his curve to the left...... search "swapping in another cam" I think that was the name of his thread.
Postby cummins12club » Thu Dec 20, 2012 10:26 am
Will do I thought he had a 181 and swapped it for a 188 or vise versa ill have to look when u say to the left do u mean lower rpm range?
cummins12club
Postby RCCUMMINS89 » Thu Dec 20, 2012 11:13 am
Yep, shifted the curve to the lower rpm range.
Postby cummins12club » Thu Dec 20, 2012 11:21 am
Hmmm for some reason can't find it must not be looking hard enough
cummins12club
Postby lazyjoe » Thu Dec 20, 2012 11:38 am
93, W350, auto, DTT convertor, 4.10's, GDS 60mm with 14cm, piston l/p, 2nd gen air horn. 366 spring. boost, and pyro.
91, W250, 360 gas, auto, 4.10
95, 2500, 4/4, 5" turbo back. So far.
lazyjoe
Postby cummins12club » Thu Dec 20, 2012 9:13 pm
Yup makes since that it would make a difference
cummins12club
