Dana 60 lockout hub
Re: Dana 60 lockout hub
Postby CumminsPower59 » Wed Jan 02, 2013 7:47 am
Yup ;)
Postby Farmboy » Wed Jan 02, 2013 10:29 am
anyone have one or a part number for one?
Farmboy
Postby CumminsPower59 » Wed Jan 02, 2013 10:52 am
I might have one, I can check tonight when I get home...
Postby NJDodge » Mon Jan 07, 2013 9:42 pm
On this note, sorry if I'm butting in, but I have a Dana 60F on my 1990 W250 and it has selectro hubs. I need the hub bearing? Or at least I think that's what it's called. My front right wheel bearing blew out and the axle ate the bearing around the sleeve, if you have one please let me know! I need it! lol Or bushing..It's the aluminum piece on the sleeve.
NJDodge
Postby CumminsPower59 » Tue Jan 08, 2013 5:33 am
Sh!t! Sorry Farmboy, I totally forgot about this :( I do have a snap ring that may work...
NJDodge, Post up a picture of what you are describing please, it's been a while since I messed with a Selectro hub...
Postby RumbleFish » Tue Jan 08, 2013 2:46 pm
Somebody warrantied a set of these at work the other day. I'll see if I can borrow a snap ring before it gets sent back.
Postby Farmboy » Thu Jan 10, 2013 6:45 am
Hey no sweat.. I have been stuck on the couch with the flu for the past week and didn't even fire up the computer..
Farmboy
Postby NJDodge » Sat Jan 12, 2013 12:30 pm
I need the assembly bushing.
NJDodge
Postby Farmboy » Tue Jan 15, 2013 2:38 pm
CumminsPower59 wrote: I do have a snap ring that may work...
How much you want for it... I will pay for shipping.. Shoot me a PM
Farmboy
Postby CumminsPower59 » Tue Jan 15, 2013 3:10 pm
PM sent ;)
Postby bubba » Wed Jan 16, 2013 7:15 pm
Not trying to hi jack your thread or anything but since it looks like your issue has been resolved, I would like to ask a question about mine. When I got the truck the left lockout hub was missing several pieces. I bought two brand new warns and they rode around in the truck for a year. I change the king pins and wheel bearings and the left outboard shaft because part of the hub had gotten jammed in there and nearly cut the outboard shaft in half. Anyway I go to put the new warn lockout hubs in and the large internal snap ring that holds the lockout hub itself in won't go in because of a ridge around the groove for the snap ring. Ever have this trouble? It should be ok to grind the ridge down, right?
1992 Dodge W350 CTD A518 DRW Flatbed
bubba
Postby CumminsPower59 » Wed Jan 16, 2013 8:40 pm
That snap ring will go in, it just takes a little work. The new snap rings that come with Warn's now are a very tight, and you have to put the edge in at an angle and then work it in with a small, flat screwdriver. It's even more of a pain to get out, but it can be done ;)
Postby bubba » Wed Jan 16, 2013 8:57 pm
Ok just wondering. I didn't know if they made a thinner snap ring. Thank you sir.
bubba
Postby Stockertrailer » Thu Feb 06, 2014 10:24 pm
Who builds aluminum front replacements
Stockertrailer
smoke screw?
Postby CumminsPower59 » Thu Feb 06, 2014 11:19 pm
Warn makes a very similar stock replacement units for the 90-93 and Mile Marker makes 89 and older units.
