9/16 stud conversion?
Re: 9/16 stud conversion?
Postby 93DodgeCummins » Thu Dec 08, 2011 10:03 am
You wouldnt happen to have any part numbers would you?
93DodgeCummins
Postby CumminsPower59 » Thu Dec 08, 2011 12:58 pm
I can look around tonight and see if I kept any of the boxes that the studs came in...
Postby 93DodgeCummins » Sun Jan 13, 2013 9:46 pm
Does the knurl diamter matter? I am finally to my brake project and want to change out the studs to 9/16. The k30 is similar except the knurl dia.
http://www.dormanproducts.com/p-30759-98260.aspx This is the stock stud
http://www.dormanproducts.com/p-14326-9 ... l%2520Stud
Here is the k30 stud
What do you guys think?
93DodgeCummins
Postby CumminsPower59 » Mon Jan 14, 2013 5:59 am
93DodgeCummins wrote:Does the knurl diamter matter? I am finally to my brake project and want to change out the studs to 9/16. The k30 is similar except the knurl dia.
They work. Dorman 610-283 is another part number as what you had listed. These are the exact studs that I have used on both trucks I have owned. I recently converted my 91 to 9/16" studs.
To save some coin, I bought 30 studs (10 each per box) off ebay for $18 a box and a box of used 2nd gen lugnuts (32) for $25. The other two studs I sourced locally for an additional $6. First time I did the conversion, I used the parts store and it cost me almost $200 for all new parts, the nuts were the most expensive.
Like I said above, they work, even though the diameter is 0.001 or so difference. They still don't go in easy, I used a press this time instead of a BFH :mrgreen:
Postby 93DodgeCummins » Mon Jan 14, 2013 6:13 am
Thank you very much! I do not know what I would do with out u guys
93DodgeCummins
Postby CumminsPower59 » Mon Jan 14, 2013 6:27 am
You're welcome! :thumright:
Postby 93DodgeCummins » Mon Jan 14, 2013 3:31 pm
got them on order
93DodgeCummins
Postby 93DodgeCummins » Mon Mar 11, 2013 10:25 am
Would you guys happen to have a dorman part # for converting the rears to 9/16?
93DodgeCummins
Postby CumminsPower59 » Mon Mar 11, 2013 11:29 am
Same part number, 610-283 :thumright:
Postby 93DodgeCummins » Mon Mar 11, 2013 2:40 pm
Im pretty sure they are a different style stud since they are drums... I looked at the stock stud specs for the front and back and they are different.
Stock front
knurl: .651 inches
shouder length: 15/16 inches
thread: 1/2-20
length: 2 11/16 inches
Stock rear
Knurl: .625
Shoulder length: 3/4
same thread as above
length: 1 25/32 inches
93DodgeCummins
Postby CumminsPower59 » Mon Mar 11, 2013 3:11 pm
Well, the two trucks I have converted take the same studs (9/16", pn 610-283) front and rear...
If yours are different for some strange case, let us know.
Postby bmoeller » Sat Mar 16, 2013 9:45 am
CumminsPower59 wrote: They still don't go in easy, I used a press this time instead of a BFH :mrgreen:
I love my air hammer for those jobs! Blows them right in and out. :D Especially if heavily rusted, and no torch handy. :)
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby CumminsPower59 » Sat Mar 16, 2013 9:50 am
For removal, I usually use my drilling hammer, one or two blows with that thing does the trick. Even though I have an air hammer, I will still press the new studs in, just because I have a press and I can :-P
