delivery valves?
delivery valves?
Postby turboram » Thu Jan 17, 2013 5:54 pm
Anyone ever try custom delivery valves? I just installed a set I built from vw ones and holy crap do they fuel hard .and it idles like a puller . I had to install the pump I built for testing on the puller because the camplate exploded the pump on the wifes ride
turboram
Re: delivery valves?
Postby oldestof11 » Thu Jan 17, 2013 5:56 pm
Interesting. Have any pics of the differences?
Postby turboram » Thu Jan 17, 2013 6:16 pm
No pictures ... but the vw ones don't have a relief cut in the seat to let fuel return to the rotor. But they do have a collar that need cut down and I cut them a little more than our normal ones
turboram
Postby turboram » Thu Jan 17, 2013 6:44 pm
Check out the valve on the right it has a cut in the seat that lets fuel back to the pump. The one on the left looks like the vw's I cut down
turboram
Postby RCCUMMINS89 » Thu Jan 17, 2013 8:39 pm
When is it fueling hard? Idle or all the way through.
Postby turboram » Thu Jan 17, 2013 9:07 pm
All the way . used to clean up after 3500 now heavy smoke and keeps pulling all the way to 4000
turboram
Postby RCCUMMINS89 » Thu Jan 17, 2013 9:18 pm
Ok.... you now have my attention.
Postby turboram » Fri Jan 18, 2013 5:17 am
How about I post a video of it running.....Who else has done valves? there's NO way I'm the only one, people aren't talking or something
turboram
Postby dazedandconfused » Fri Jan 18, 2013 7:03 am
Post the video. In the past people have messed with delivery valves and only noticed an increase in low end fueling. Which valves did you modify? Year and spec on vw pump ghey came from?
Postby turboram » Fri Jan 18, 2013 8:57 pm
Here is a video not the best and it was on the governor before I got to the camera. https://www.youtube.com/watch?v=5DjZ78_ ... ata_player here's a video of the idle https://www.youtube.com/watch?v=R1nkU_3 ... ata_player
turboram
Postby RCCUMMINS89 » Fri Jan 18, 2013 9:22 pm
what are mods in detail..... ie trubo, timing, afc, injectors, etc...
Postby revemup15 » Fri Jan 18, 2013 9:28 pm
Turboram you have a pm
94 p-pump
revemup15
Banned
Postby turboram » Sat Jan 19, 2013 6:04 am
Turbo is a vgt the injectors are 5x14s , timing is bumped a tooth and almost pushed to the head. Pump mods are 4200 spring , fuel screw turned all but 3 turns in and delivery valves.......oh forgot the fuel pin is reground for full fuel
turboram
Postby dazedandconfused » Sat Jan 19, 2013 6:34 am
What are you using for a supply pump?
Postby turboram » Sat Jan 19, 2013 6:55 am
The lift pump is just the factory ford gas fuel pump
turboram
Users browsing this forum: No registered users and 80 guests
