I have a 1992 Dodge Ram D-350, 5spd, and 3.54 with 93,000. I'm going to work for my father-in-law in his construction business.
What would be the best upgrades for towing 10k-15k a few times a week in arkansas ?
Thanks !
monoblock wrote:Great modification suggestions. What puzzles me is which ones are dependent on related improvements.
For example there is even a 4200rpm spring available (and 3800) but wouldn't they be ineffective without a proportional increase in fuel supply(H.O. pump as suggested) and larger injectors and/or various other tweeks to the pump?Even valve spring upgrades?
I am trying to think in terms of a package of balanced & proportional improvements -like Stage 1 Towing , Stage 2 Towing .......
monoblock wrote:Easily(I presume) towing 12,000 pounds proves the effectiveness of your upgrades.
Were the stock brakes upgraded also?
The other key component I notice in your signature is an ATS transmission(?). Would you mind sharing what convinced you to buy ATS rather than PATC or any of the other trans upgrades ?
