oldestof11 wrote:When was air over hydraulic developed? Our fire trucks have them.
Diesel wrote:I am 90% sure I remember him saying there is a visible leak that needs to be fixed because the previous owner "put a line on it" which doesn't explain to me why its leaking. But with that said it sounds like the thing isn't air brake.
Diesel wrote:SO now I need it to be 26,000lbs or less right?
PToombs wrote:Even if it is 28k, if you register it for 25,999 or less you can drive it. It's what it's registered for, not the capacity.
