delivery valves?
Re: delivery valves?
Postby RCCUMMINS89 » Wed Jan 30, 2013 12:47 pm
Good deal......
Postby oldestof11 » Wed Jan 30, 2013 1:22 pm
Nice!
A video would be nice too!
Postby BC847 » Wed Jan 30, 2013 2:17 pm
Looking forward to some positive results. :)
I don't know if you've said so, but you'll be doing a Back-To-Back comparison, correct? :?:
Postby RCCUMMINS89 » Wed Jan 30, 2013 2:20 pm
Me too..... I think that they will in fact increase fuel by a decent amount. I just wish someone could tell me that it wouldn't be any harder on the injectors.
Makes me think of the common rails... lines being constantly pressurized... they need electronic injectors.
Postby revemup15 » Wed Jan 30, 2013 6:46 pm
Im ready to see some results nick..
94 p-pump
revemup15
Banned
Postby turboram » Wed Jan 30, 2013 7:10 pm
Yes I will be running back to back only change is delivery valves...... I would take the hose along for giggles but the wife would kill me if I blew the motor in her ride
This dyno we use is conservative and he runs it with no correction factor too..... a 600 hp diesel on his makes 700 on other dyno's
turboram
Postby RCCUMMINS89 » Wed Jan 30, 2013 7:27 pm
OOOOHHHHH.... I'm getting excited.
Postby rockmike » Thu Jan 31, 2013 9:49 am
I see it now im going to liquidate all other rigs in my drioveway and find me a light weight I/C cummins truck and build me a play truck!
These trucks so addicting! lol
93 d350 extra cab 5 speed dually.
Mods: hx35,rotated fuel pin,bosch 190 inj.,BHAF with smooth intake tube,3200 rpm spring,M&H dynamic timing spacer,isspro EGT and boost gauge,Auto meter tach, fuel press. gauge.Diamond eye 4" exhaust,Sno Stage 2 W/M kit.
Real trucks dont use spark plugs!
rockmike
Postby cummins12club » Thu Jan 31, 2013 3:21 pm
I thought vp pumps don't have delivery valves?
cummins12club
Postby RCCUMMINS89 » Thu Jan 31, 2013 3:25 pm
I don't believe they do.... oldestof11, I bet will know how they work a little bit. I know nothing of a vp pump.
Postby oldestof11 » Thu Jan 31, 2013 3:48 pm
They have a "anti-drain back" valve but not a real "delivery" valve from what I have been able to find.
Postby RCCUMMINS89 » Thu Jan 31, 2013 4:05 pm
OK... so they have an anti drain back line... meaning that it keeps the line fully pressurized? Also, the vp trucks are a full mechanical injector or not?
Postby skilletky » Thu Jan 31, 2013 4:24 pm
RCCUMMINS89 wrote:OK... so they have an anti drain back line... meaning that it keeps the line fully pressurized? Also, the vp trucks are a full mechanical injector or not?
they are mechanical. work the same as a 12 valve injector
skilletky
Postby RCCUMMINS89 » Thu Jan 31, 2013 5:02 pm
That's what I thought.
Postby turboram » Thu Jan 31, 2013 6:58 pm
In stock form the vp doesn't technically have delivery valves.
turboram
