Front leaf springs
Front leaf springs
Postby blakemartz12 » Tue Feb 05, 2013 5:55 pm
Anyone have a good source for front leaf springs designed to handle the weight of the Cummins? I don't really care if they are lift springs or stock height, I would just like it to be level. Also, has anyone swaped to coils from the 2nd gen trucks? Thanks
blakemartz12
Re: Front leaf springs
Postby walkerkd » Tue Feb 05, 2013 6:30 pm
i know alot of people say skyjaker are crap and theres several others options out from my understanding. Im thinking about rearching my stock springs and add a leaf front and rear. here in Fort Worth we have Ray's Champion Springs he does big rig stuff and i spoke him about sagging he said he would stand by his work. maybe thats an option for you too.
walkerkd
Postby kwrank » Tue Feb 05, 2013 8:11 pm
benz spring, in portland, oregon, has done me right on two trucks. old world steel and service.
92 W250 CC HX35/16 366 190's lp piston lift hughes converter
kwrank
Postby Tacoclaw » Tue Feb 05, 2013 8:21 pm
Yup, usually big-rig spring shops can get ahold of stock replacement springs no problem. They may try to talk you into a rearch, but depending on how long you intend to keep your truck you may be better off buying new.
Postby lopez dodge » Thu Feb 07, 2013 3:49 pm
there is a 1st gen around santa fe that has what appears to be 2nd gen front suspension , i only got a quick look and no chance to talk to the guy driving. so it can be done , but at what cost i don't know
1991.5 ..getrag super40. 40,horse injectors,4"to 6" exhaust , bhaf 2nd gen intake,custom pin timed to the head ..1/4 14.9@93mph 5,500' with a little propane
lopez dodge
Postby bmoeller » Sat Feb 09, 2013 4:13 am
Or, it's a 1st gen body on a 2nd gen frame...............
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby lopez dodge » Mon Feb 11, 2013 7:48 am
good question only time i ever saw that truck.
lopez dodge
Postby Mark Nixon » Mon Feb 11, 2013 10:11 am
There's a reason I call the 1st gen 4X4, standard cabs "Jumping Rams". :roll:
Worst. Riding. Trucks. EVER.
Add a trailer and it's very horrible.
Postby m880cummins » Mon Feb 11, 2013 4:13 pm
Alcans are the best quality springs for the money. Also, custom suspension has 2" parabolic springs but they cost a little bit more than alcans.
Skyjackers are about half that of Alcan but you will be much more happy with alcans because they will last much longer, made of better material and ride smoother. Alcan builds to your specs too. I just bought a pair from them that are 6" of lift to my specs and vehicle modifications (everything from the addition of a 2nd battery to heavier off road bumpers). Alcans were $550 shipped to my door and they take about 3 weeks to show up and are available in stock or any lift height you want.
Skyjackers are around $250 a pair last time I checked. NEVER BUY ADD A LEAF springs for these trucks. They are dangerous and will wear through the top spring leaf and cause the spring to fail.
If you are Mr. Lowbuck which is nothing bad, I have done a junkyard conversion on my last truck using 3/4 ton leafs from a late 1960s dodge pickup. They have one more leaf, military wrap (keeps the leaves from negative arching as easily) and ride smoother than stock. Install poly bushings in these and you will have a more level truck with a better suspension ride up front.
It all depends on how long you want to keep it, what your roads are like (anythings better than PA roads!) and what you have for tires. A 33" tire is about the biggest you want with stock suspension. Read Alcan spring's website to learn more about spring styles.
Alcan spring:
http://www.alcanspring.com/
Custom suspension:
http://www.customsuspension.com/store/p ... ts_id=1861
New diesel stock spring on left, junkyard leaf on right. Military wrap seen here on the junkyard spring eye (right).
Junkard spring seen here still has 3/4" of positive arch. They stayed like this for the 5000 miles I drove it before I sold the truck. The springs are OEM factory so they had plenty of miles and were well broken in so I knew they wouldn't settle any more as I drove it.
New stock on passenger side, late 60s dodge on drivers:
Charlie
SUNY Maritime Class of 2017!
m880cummins
Postby 91bluecummins » Thu Feb 21, 2013 5:51 pm
I got all the hd springs around 7 pack in front and 8 pack in rear from fatbobs.com
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Postby PToombs » Fri Feb 22, 2013 5:43 pm
I went to that fatbobs to check on springs and I think I did something wrong. http://fatbobs.com/
Now I want ribs, wtf?
Postby bmoeller » Sat Feb 23, 2013 8:45 pm
bmoeller
Postby matthewh » Sun Feb 24, 2013 2:52 am
I bought a set of front springs off a W350 from a local pick & pull. Truck only had 100k on it, and other than alittle rust, they looked in good shape.
matthewh
Postby PToombs » Sun Feb 24, 2013 2:50 pm
Bryan, I found it. I like the prices better on mine though! ;)
Postby 91bluecummins » Mon Feb 25, 2013 5:50 pm
Yeah fatbobs garage.com that's it I love mine a little like a hay wagon though. I just tell everybody that's my racing suspension.lol
91bluecummins
Users browsing this forum: No registered users and 112 guests
