It allows for twice the timing advance over cummins, something like 20-22 degrees
I built an air pressure adapter for the case and found out it takes over 50psi to start timing advance, 90to make half, and 120 to create full advance. And if I were to shorten it a little there could be 30 deg total of timing advance
to change out the springs for timing curve tuning
