Mark Nixon wrote:Wow, this all reads as being more complicated than it actually is.
Unsubscribing before my head explodes.
D-dog357 wrote:Please correct me it I'm wrong.
The governor spring in diesel engines achieve 2 things at the same time. It helps ensure a steady RPM at a given throttle setting under varying loads while preventing a run-away engine.
The governor sets the max RPM you can run the engine with or without a load and not run-away. As opposed to most gassers that will grenade at full throttle with no load.
It's a dynamic controller. You can very the load on the engine and the governor will change the fuel flow to maintain that RPM within the springs parameters. Just like when you go up a hill as the engine slows it will allow flow more fuel. If your against the governor it will try to keep you at that speed.
Since we rarely drive at full throttle it acts more like a dampener. The higher the RPM the more it affects fuel flow up to the point where it won't allow any more fuel/RPMs. The stronger the spring - the higher the RPMs it will allow the engine to rev to. Also the less peddle movement is needed to increase RPMs as the spring stretches less so it maintains more fuel over a longer amount of peddle travel.
If you replaced the spring with a rod, it would still try to limit the max RPMs the engine could turn but it would have to fight the peddle pressure directly. I suppose you could remove the whole assembly with some mods. You wouldn't need a spring and it would act more like a gasser - can you say runaway ?![]()
For me it as clear as mud
