dash swap.
both inside and out
dash swap.
Postby Dodgecrawler2011 » Thu Feb 21, 2013 1:08 pm
Whats all invovled beside the screws under the windshield. Neither truck has windshield in it at the moment
Dodgecrawler2011
Re: dash swap.
Postby dazedandconfused » Thu Feb 21, 2013 1:35 pm
Drop the steering column out and there is a bolt n the passenger side and driver side up by the kick panel
Re: dash swap.
Postby bmoeller » Sat Feb 23, 2013 9:04 am
Those bolts don't need to come out, to swap a dash. Those bolts are for the bracket that the lower dash is screwed to.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: dash swap.
Postby dazedandconfused » Sat Feb 23, 2013 9:09 am
I had to remove them to get my dash out.
Re: dash swap.
Postby bmoeller » Sat Feb 23, 2013 1:58 pm
The ones I pulled out, were already broke off on the ends! :lol:
bmoeller
Re: dash swap.
Postby Dodgecrawler2011 » Sun Feb 24, 2013 10:29 pm
I got it swapped. Technically dont have to take them all the way just loosen them :D
Dodgecrawler2011
Re: dash swap.
Postby Mark Nixon » Fri Mar 01, 2013 5:42 pm
As many dashes as I have had to pull, I can do them blindfolded.
I've done the whole bit, windshield, harness and all, out and back in the vehicle, glass and all, in just under 4 hours.
By myself.
It's like I have a blueprint of where the bolts are, and what wires to disconnect, burned into my mind.
Heater box swaps are the same way. :D
Re: dash swap.
Postby Dodgecrawler2011 » Thu Mar 07, 2013 8:32 pm
Mark Nixon wrote:As many dashes as I have had to pull, I can do them blindfolded.
By myself.
ok theres a giant white connector hangin under my dash where excatlt does it go. Cant seem to find the female end of it. Everthing works cept the blower motor
Dodgecrawler2011
Return to Body
