Diesel Power Magazine 1st gen buildup
Re: Diesel Power Magazine 1st gen buildup
Postby revemup15 » Sun Jan 06, 2013 4:07 pm
Keep up the good work jason
94 p-pump
revemup15
Banned
Postby coolhand_luke » Fri Feb 08, 2013 9:38 pm
I have been reading on the 14mm pump head and I need some info from a credible source. All I can find is negative hype on the 14mm and that it doesn't hold up well and it's a waste of money and blah blah blah.... I have found good builds like "rustbucket" that have had good results with one. I'm leaning towards the thinking that it's a must if big power is a goal. What supporting mods are needed when going the 14mm way? Strong lift pump? What are a good set of injectors to match with a 14mm? I will slowly be building my 1st gen to make big streetable power. Thanks for any info and knowledge.
coolhand_luke
Postby JQmile » Sun Feb 10, 2013 11:53 pm
What do you want to do with the truck? Limit the rpm, buy a good lift pump, and you have a shot....
JQmile
Postby revemup15 » Mon Feb 11, 2013 2:27 am
Rule of thumb when you run a 14mm..... 3200 gov spring and airdog or liftpump of that sort
94 p-pump
revemup15
Banned
Postby JQmile » Wed Feb 20, 2013 9:49 pm
New numbers coming soon with traction and slicks! :D
JQmile
Postby Deathrod » Fri Feb 22, 2013 1:27 pm
Wanna race?????
Deathrod
Postby oldestof11 » Fri Feb 22, 2013 3:25 pm
I want to see that, where is my popcorn?
Postby 1STGENFARMBOY » Fri Feb 22, 2013 3:31 pm
there better be a vid of said race ! ! ! ! ! !
Postby JQmile » Sun Feb 24, 2013 11:10 pm
Fuel only? Or spray? Stop, or from a roll? I'm game! :D
JQmile
Postby Deathrod » Mon Feb 25, 2013 9:38 pm
I think you might kill me, but who knows.....btw I don't have slicks, spray, still runnin stock sticks.....
Deathrod
Postby RCCUMMINS89 » Mon Feb 25, 2013 9:55 pm
I bet all fuel to all fuel, it would be closer than some might think..... just because the ol' model A is super super light.
Postby JQmile » Wed Feb 27, 2013 8:30 pm
https://www.youtube.com/watch?v=aHsnNi_O9ug
I agree fuel to fuel would be close....what's your top speed? We could do this ^^^^^^ :D
JQmile
Postby Deathrod » Fri Mar 01, 2013 10:50 am
well I've only gone about 110mph in it so far, i think it would do 130? maybe close to 140? Its really hard to say i know aerodynamics come into play a lot at those speeds, while its not aerodynamic it is a much smaller footprint then a truck. It does feel like gearing would run out before it becoming an issue with the power to do it.
But just a quick street drag????
Deathrod
Postby oldestof11 » Fri Mar 01, 2013 6:15 pm
Jason would have you in that race... 3.07's plus the 47RH OD AND the GV OD unit...
Postby dazedandconfused » Fri Mar 01, 2013 6:51 pm
I dont know his car has a 518 i thought and 2.xx rear axle. If so it should cruise pretty dang fast.
