blackvmax07 wrote:My truck right now is only running about 21psi, does that sound right? Its an auto though, but no idea on gearing, how do I find that out?
RCCUMMINS89 wrote:I'd throw on a 12 cm housing to the big h1c
bmoeller wrote:RCCUMMINS89 wrote:I'd throw on a 12 cm housing to the big h1c
NOT if one has 4.10 gears! Chokes the motor down too much. A 14 housing is a tight as I'd go on one.
I'd work on more airflow improvements, before adding more fuel.
blackvmax07 wrote:Thanks for all the info guys, where can I grt a 14mm housing and how much do the normaly cost?
