Smoke From Steering Column
Postby Greenleaf » Sat Aug 22, 2009 1:38 pm
I had the A/C and blower motor on max output last weekend and for the first time I witnessed smoke form the around the key switch.
The bottom cover was very hot and I sourced it to the the two 12 gauge battery power "feed" wires from the battery to the ignition switch. They have been hot for some time as evidenced from the cracked plactic cover located at the underside of the column.
I installed a relay to power the blower and electric windows as opposed to the key switch.
I hope to test my work by monitoring the temp of the two wires feeding the ignition switch.
GL
Greenleaf
tech specialist/mod
Postby Philip » Sat Aug 22, 2009 3:05 pm
It should help a lot with thr relays installed.
I'll make sure to bring my DC amp meter with me at S.O.P. #6.
Postby PToombs » Sat Aug 22, 2009 5:18 pm
About the only reason I'm glad I don't have AC! ;)
Postby Greenleaf » Wed Aug 26, 2009 9:37 am
so far......
The wires related to the circuit are cool as cucumbers.
Thanks Phillip!!
Greenleaf
tech specialist/mod
Re: Smoke From Steering Column
Postby 93DodgeCummins » Sun Mar 10, 2013 9:37 pm
I have this same problem... Where exactly did you tap in the factory harness with your relay?
93DodgeCummins
Return to Electrical
