Cummins/82 C10
Cummins/82 C10
Postby ellis93 » Mon Mar 11, 2013 8:02 pm
Anyone know of a really good conversion tread on any forum(s) that gives a detailed account of an Cummins swap into a square body Chevy. I've been over on 4bt swap and I've found some swaps but I've not searched it out very hard,kinda wondering if any of you all might have a lead on one....thanks
Re: Cummins/82 C10
Postby dazedandconfused » Tue Mar 12, 2013 4:32 am
There have been a few on CompD.
Re: Cummins/82 C10
Postby ellis93 » Tue Mar 12, 2013 10:56 am
I'll snoop around Andy,thanks.
On doing this swap......would anyone consider going none innercooled for this. It's 2500lbs of truck and will never see more than itself and occupants for weight,reckon I need it :scratch:
I might not even fool with a/c with this thing either :lol:
Re: Cummins/82 C10
Postby dazedandconfused » Tue Mar 12, 2013 12:02 pm
I think i would still intercool it.
Re: Cummins/82 C10
Postby ellis93 » Tue Mar 12, 2013 12:44 pm
dazedandconfused wrote:I think i would still intercool it.
I probably will but I think it'll be a beooch to make the condenser/ic/trans cooler stack up to fit with a factory grill,it may make me run one of those weirdo phantom grills :puker: like all the lowride/hot rods do. It's still all talk right now,the dang truck has been disassembled for 6yrs behind the shop,I'm less motivated than the tacoclaw :lol:
Re: Cummins/82 C10
Postby dazedandconfused » Tue Mar 12, 2013 1:03 pm
Re: Cummins/82 C10
Postby ellis93 » Tue Mar 12, 2013 2:25 pm
dazedandconfused wrote:http://www.competitiondiesel.com/forums/showthread.php?t=115873&highlight=c10
Here is one build.
Looks like that one is dead at the moment :roll: some folks :lol: I'm sure mines gonna be the same way :oops:
Re: Cummins/82 C10
Postby oldestof11 » Tue Mar 12, 2013 3:06 pm
I tried to do it in a 87 Burb. Some notes I remember...
All these notes are also using the 1st Gen rubber mounts and the factory Chevy engine stamped pieces where the 350 engine mounts bolted to. I moved these back a few inches and slotted the holes. This allowed for minimal fab and I had about .5" between the back of the engine trans combo (727) and the pinch weld/firewall. I had .5" clearance with the Chevy front crossmember and the oil pan in all spots.
The 727 mount was right where the 700R4 crossmember was at.
The IC thing isn't going to fit if you try to use the stock 1st Gen radiator and electric. I cut into the core support about 1.5" and that left about that amount in front of the engine to radiator.
To keep the A/C, an industrial rear mount should be used or a 3rd Gen exhaust manifold ported to the "D" shaped ports of the 12v.
A custom DP is needed for the exhaust manifold.
With the turbo in this spot, the charge pipe from the IC to intake horn is about dam perfect if you can make a spacer to raise the horn and turn it 180* and clock the turbo. This does create a hood clearance issue BUT a cowl hood should take care of that.
A Freightliner A/C and Alt mount would be nice so no trimming of the crossmember and frame rail isnt needed.
The Dodge frame rails at the mounts is around 33", Chevy was 32" or 31.5".
Hope that helps.
Re: Cummins/82 C10
Postby ellis93 » Tue Mar 12, 2013 4:05 pm
Thanks Jon :thumleft:
Figured I'd post up what I'm working with,the old Chevy is in terrible shape,so bad I don't even know if it's even sane to fool with :lol: I probably should of scraped it 5yrs ago :/
I've been saving another cab with good rockers for it for the last 2yrs,its been without a bed for the same amount of time. I have it....in pieces...in a pile :lol:
This is what I'm killing 8)
Sad thing is that this truck is in better shape than the Chevy :lol:
This right here
Is all I want....that and the trans
Re: Cummins/82 C10
Postby ellis93 » Tue Mar 12, 2013 4:11 pm
one pile of bed :lol: Image
Re: Cummins/82 C10
Postby revemup15 » Tue Mar 12, 2013 5:24 pm
The dodge looks nicer than the obamamobile lmfao... whatever happens post alot of pics!
94 p-pump
revemup15
Banned
Re: Cummins/82 C10
Postby BobS » Wed Mar 13, 2013 4:36 am
Hey Mr. Ellis - Scott [aka Crewcab59] who is a vendor over on 4btswaps was selling sets of 6BT engine mount adapters that adapted a 1st gen mounting to use the GM factory motor mounts in the stock position. In other words, no redrilling of the frame required. I'm not sure if they were for both 4WD & 2WD but they mounted the engine low enough that there was no body lift required. Scott has not been all of that active lately & I believe it may take a bit of time to get a reply back from him. His mounts were cheap compared to places like auto world and the other big buck suppliers.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Re: Cummins/82 C10
Postby ellis93 » Wed Mar 13, 2013 5:48 am
Thank you Mr Bob,I'll check on them.
Re: Cummins/82 C10
Postby RCCUMMINS89 » Thu Mar 14, 2013 8:48 pm
thing should be pretty sweet.
Subscribed
Re: Cummins/82 C10
Postby ellis93 » Tue Mar 19, 2013 6:26 pm
Oh boy,looks like I wont be using the computer now
http://www.transmissioncenter.net/SwapInformation.htm
