VE Injection Pump Rebuild
Re: VE Injection Pump Rebuild
Postby Mark Nixon » Sat Mar 09, 2013 2:58 pm
The thing with solenoids is that they can tend to act like amplifiers when you disconnect them, at that point there is a surge of energy that can "bite" you and I have had it happen numerous times.
Not saying this is what happened, but it's as plausible as anything else we've discussed.
Personally, I'd just look the rest over, then replace the seals, cam plate, rollers and the springs, then give it another whirl.
Postby Luther Grimace » Sat Mar 09, 2013 4:00 pm
Hopefully the springs won't break the bank. I am gonna get all 4 springs. I got the rebuild kit this yesterday so hopefully they have the rollers, camplate, and springs in stock. Might even grab a 3200 rpm spring while I'm in there :D You wouldn't by chance have the spring height would you? I wonder if you have to recalibrate the pump if you put a 14mm head on? I thought about getting the 4 mm camplate but I have heard too many bad things about it.
Luther Grimace
Postby Luther Grimace » Fri Mar 15, 2013 8:55 am
How do you replace the seal where the pin goes for the fuel pin? It's supposed to be the one that causes it to leak fuel out of the vent.
Luther Grimace
Postby Mark Nixon » Fri Mar 15, 2013 9:31 am
In the side of the pump top there are 2 steel balls, you have to drive them both out to get the AFC lever pin out.
Drive one in, the other pops out, then drive the pin backwards and the other falls out.
Remove the pin and the lever comes out.
On the front of the pump, behind where the throtle shaft and levers would be located, there is a plug with a hexagon hole, remove it.
Behind that plug is the fuel pin, remove it.
The hole the pin was in has a 4.5mm hollow "set screw". This is actually what holds the 'O' ring for the pin.
Use a 4.5mm allen wrench to remove the "set screw", then pick the junk 'O' ring out.
Postby Luther Grimace » Fri Mar 15, 2013 7:16 pm
Thanks! I couldn't figure how to get the plug out. I ended up using a torx to get it out. Also mine didn't have an o ring. It had an aluminum washer. I got the pump got back together and cranked it up. It runs but it is still missing :( I think I am just gonna get the injectors replaced with some 5 x 12s. I really am at a loss as what else could be the problem. Only part in my pump that is left from the original is the case. I bought a used pump with a broken ear off the case and a broken governor lever with the same serial number and swapped all the internals into my case. My distributor plunger springs were .010 shorter than the other case. Any ideas fellas?
Luther Grimace
Postby Mark Nixon » Fri Mar 15, 2013 7:36 pm
CMIIW, but haven't you always had the miss?
I'm assuming you didn't change the injectors from when you had the bad piston....
Postby Luther Grimace » Fri Mar 15, 2013 8:50 pm
No the miss just started at about 10 minutes run time on this engine. And yes I reused injectors.
Last edited by Luther Grimace on Fri Mar 15, 2013 8:52 pm, edited 2 times in total.
Luther Grimace
Postby Mark Nixon » Fri Mar 15, 2013 8:52 pm
Same injectors?
Postby Luther Grimace » Fri Mar 15, 2013 8:54 pm
Yes I reused the original injectors. Could just be a strange coincidence that my pump and injectors messed up at the same time.
Luther Grimace
Postby Mark Nixon » Fri Mar 15, 2013 9:20 pm
CMIIW, but didn't the old engine have a chowed piston?
See where I'm going here?
Postby Luther Grimace » Fri Mar 15, 2013 10:10 pm
No I'm not catching your drift.
Luther Grimace
Postby Mark Nixon » Fri Mar 15, 2013 10:15 pm
Luther Grimace wrote:No I'm not catching your drift.
I don't "drift", not a ricer. :lol:
Didn't number 6 piston on your old engine have some damage?
Looking back on it, could it be possible that a bad injector is the whole issue?
Postby Luther Grimace » Fri Mar 15, 2013 10:18 pm
Possibly. I guess with this many miles its time for some new ones anyway. I think I am gonna order some 5 x 12s on Monday from DAP.
Luther Grimace
Postby Luther Grimace » Wed Mar 20, 2013 6:29 pm
What should my lift pump pressure be? I'm getting like 4-6 psi.
Luther Grimace
Postby Mark Nixon » Wed Mar 20, 2013 6:45 pm
That's workable, some trucks suck it to zero, though I think 6psi is what is preferred.
It'd be nice to have ~15psi.
