12 MM EXAUST HOUSING
Postby OLDEARL93 » Sat Jan 05, 2008 2:54 am
WANTED TO KNOW IF ANYONE HAS HAD ANY EGT PROBLEM WITH GHANGING FROM 18.5 HOUSING ON A 93 TO A 12 WATEGATED , I DO NOT TOW HEAVY BUT I DO NOT WANT TEMPERATURE IN THE 1200 DEGRES , ANY ADVISE WILL BE HELPFULL , THANKS
OLDEARL93
Postby 92 D/UNIT » Sat Jan 05, 2008 11:11 am
DEPENDS ON WHAT MODS YOUVE DONE, I RAN ONE WITH WITH 350 HP AND WAS FINE FOR CRUISING ANG ROMPING BUT WASNT GOOD FOR TOWING.
388/886
92 D/UNIT
Postby cummins king » Sat Jan 05, 2008 11:13 am
12cm is only really good for std. tranny, otherwise you should us a 14cm or a 16cm, your etg's will go up with a 12cm
you should update your signature so we know what you have
93 4X4 auto
cummins king
Postby OLDEARL93 » Sat Jan 05, 2008 8:21 pm
I DO HAVE A 5 SP WILL MY EGT'S GO UP ALOT
93 4X4 EXTRA CAB 5 SP. GERT.EGT,BOOST ,RPM GAUGE,TIMMING AD,PUMP TWEEKED,NEW HX35,REST STOCK
OLDEARL93
Postby CumminsPride » Sun Jan 06, 2008 6:50 am
Only if you lug it hard.
Wade
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby OLDEARL93 » Sun Jan 06, 2008 10:52 am
I DO NOT UNDERSTAND DO YOU MEAN IF I DO NOT USE ENOUGH RPM'S AL I WANT IS TO GET RID OF THE TURBO LAG I HAVE WITH THE STOCK 18.5 IT DOES SPOOL UNTIL 1850 RPM'S AND THE LAG IS VERY BAD ,BUT EGT ARE OK WHEN I DRIVE AT HIGH SPEED ,HAS ANY ONE EXPERIMENTED WITH THIS THANKS
OLDEARL93
Postby cummins king » Sun Jan 06, 2008 11:33 am
12cm will really get rid of the lag but when your on the pettle it will make the etgs go hi, i would us the 14cm you get rid of the lag and you will get alot more preformace, and lower etgs
93 4X4 auto
cummins king
Postby OLDEARL93 » Sun Jan 06, 2008 7:26 pm
HEY KING WHAT EGT'S ARE YOU RUNNING AT HIGH SPEEDS
OLDEARL93
Postby eyoung429 » Mon Jan 07, 2008 6:40 am
Your egt's will go higher with the 12cm depending on how you drive, the type of terrain and THE AMOUNT THAT YOU POST IN CAPS@!!!!!
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Postby burnt_servo » Mon Jan 07, 2008 10:23 am
eyoung429 wrote:Your egt's will go higher with the 12cm depending on how you drive, the type of terrain and THE AMOUNT THAT YOU POST IN CAPS@!!!!!
i wonder if he knows that typing in caps is considered yelling ?
burnt_servo
Postby flashgordon » Mon Jan 07, 2008 12:55 pm
WHAT!!!!!!! :lol:
jK :tongue:
Flash
flashgordon
Postby burnt_servo » Mon Jan 07, 2008 4:37 pm
WHAT!!!!!!! :lol:
jK :tongue:
Flash
:P :) :D
burnt_servo
Postby TWorline » Mon Jan 07, 2008 7:27 pm
Maybe he is just hard of hearing. ;-)
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby cummins king » Mon Jan 07, 2008 8:19 pm
i have an auto, but iv seen 1500, with a 16cm non ic dont leave it there to long, so 12cm would be even woust
93 4X4 auto
cummins king
Postby RumbleFish » Mon Jan 07, 2008 8:23 pm
my crew had a gated 12 on it. its a real nice housing with a 5 speed. i had a couple turns on the fuel screw and pod's. with a loaded 24' enclosed trailer i could hit 1500 if i ran it hard, but i had to try it in order for it to do so. with stock injectors and a not too much turned up pump i think you'd be fine.
try it, you'll like it. i promise.
