This was in a Feb '10 post, but I doubt he's changed since then. This is the S475 I believe, same one I have.bgilbert wrote:171702 is the primary I'm using.
AHineman wrote: his sale ad on here.
PToombs wrote:Ok, time for more questions! I flipped the manifold (ATS) and now the S300 won't go on, it hits the manifold. Am I supposed to put a spacer in there?
And #2, wow, there's not much room for that big turbo under the little one!
Mark Nixon wrote:A smart as people here are, you'd think you guys could use PROPER TERMINOLOGY.
COMPOUNDS would be more appropriate.
TWINS are for V-6s or V-8s, or if you're ingenious enough to run split manifolds on inlines, at which point you use 2 turbos of similar sizes.
