now I've a smoke issue w/uncontrolled fits of anger and rage
Re: now I've a smoke issue
Postby ellis93 » Mon Apr 08, 2013 2:54 pm
Tacoclaw wrote:Could index your throttle arm and then try your fuel screw again, but since you're not looking to hotrod anymore there's not much use. :P
Really there isn't,but...... :lol:
It really depends on how it pulls,if it does well with a trailer it stays as is.
Postby ellis93 » Mon Apr 08, 2013 2:57 pm
RCCUMMINS89 wrote:Well, it's not maxed. But, maybe it's still got room to go? It should be able to be turned in about 3 turns from stock, then the factory short screw will bottom out.
Where is your idle screw? On most i/c pumps when the screw is bottomed out, they'll idle with no idle screw.
About factory setting,I haven't really moved it much. With out it in there the truck would die out. There maybe something hit on with the claws statement.
Postby oldestof11 » Mon Apr 08, 2013 3:45 pm
I didn't see a LP in your sig so I was assuming you had the stocker.
Stupid question but how old is your fuel filter?
Do you have a W/G on your housing? If so, is it wired, hooked up, open pressure?
Postby ellis93 » Mon Apr 08, 2013 4:40 pm
oldestof11 wrote:I didn't see a LP in your sig so I was assuming you had the stocker.
Sorry Jon,reckon I should update my sig :oops: . The fuel filter is maybe 6months old,could use one I'd guess,as far as waste gate.....it's wired shut. I don't/didn't see a need for it. I never see 15/20lbs driving normal (pawpaw style :mrgreen: ) mostly,only time it builds 30+ is crawling up on it,even then the hawk eye is on the gauge.
Postby oldestof11 » Mon Apr 08, 2013 4:46 pm
Bet you might have s something wrong with the gate. Check that too
Postby ellis93 » Mon Apr 08, 2013 6:07 pm
Will do Jon
Oh man good times :lol: just know decided I have made a day and wanted to leave the shop,went out to crank the dodge to let her warm.....oh my God that thing ran like schit for just a second and then cleared up. WTH :evil:
Postby dazedandconfused » Mon Apr 08, 2013 6:13 pm
Getting air in the system?
Postby RCCUMMINS89 » Mon Apr 08, 2013 6:22 pm
That's what it sounds like to me..... your idle isn't set too low is it?
Postby ellis93 » Mon Apr 08, 2013 6:51 pm
Idle definitely is not low...1k and nice and smooth.
Air huh? why all of a sudden would I be sucking air after an injector install? Stranger stuff has happened to me :lol:
the ride to the house was nice and smooth 8) powercame on smoothly and steadily.
Postby RCCUMMINS89 » Mon Apr 08, 2013 7:01 pm
If your idle screw is almost where it was stock (probably 1/2" out ) Your power screw shouldn't be bottomed out, assuming your indexing is on the 2nd mark.....which is usually the stock mark.
All that aside, has it ever idled weird for a few before? Not sure where you could be sucking air or if that's what it was... but everytime I've had a rough idle or funky idle was when I had just done something and had air in the lines.
Postby ellis93 » Mon Apr 08, 2013 7:04 pm
RCCUMMINS89 wrote:????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
:lol: that's what I'm thinking too!
Postby BC847 » Mon Apr 08, 2013 7:20 pm
After reading this entire thread, I'm confused as to where you are now.
Still excessive haze at idle? Are those VCO type nozzles with a large sac?
Postby Tacoclaw » Mon Apr 08, 2013 7:21 pm
Sounds like he's got an oversensitive driver in the seat to me, just throw the key in the ignition and go. 8)
Postby ellis93 » Mon Apr 08, 2013 7:31 pm
BC847 wrote:After reading this entire thread, I'm confused as to where you are now.
Right now I have no haze,light to moderate smoke.....all of which is acceptable now thru the new injectors and timing changes. Now I have the poor cold running crap with it clearing up quickly.
The injectors are 210 horse ppump nozzles that rc had flow honed for me and set to 245bar.
No I'm not overly sensitive,my truck is just expected to run a certain way and it's not.
Postby ellis93 » Tue Apr 09, 2013 6:04 am
Found fuel out the bottom of the pump :x guess that's my poor cold start. I dried it off and cranked it up,ran it and no fuel appeared,shut it down and checked it 30min later and its damp.
