now I've a smoke issue w/uncontrolled fits of anger and rage
Re: now I've a smoke issue w/uncontrolled fits of anger and rage
Postby oldestof11 » Tue Apr 09, 2013 10:20 am
O ring on back side of pump ksb cover. Mine did that and then it eventually blew out.
Postby RCCUMMINS89 » Tue Apr 09, 2013 10:24 am
I had a leak back there when I originally bought the donor truck. It didn't affect starting or idling on my mess, but it would make sense as the injection pump would lose some prime
Postby ellis93 » Tue Apr 09, 2013 10:29 am
oldestof11 wrote:O ring on back side of pump ksb cover. Mine did that and then it eventually blew out.
That's what I'm thinking Jon. Was hopping to have time to look into it today but its raining and I can't get it in the shop :(
I still have the leftovers from my 366 install so I should be set for parts.
Jon did yours idle funny then clear up at start up?
Postby ellis93 » Tue Apr 09, 2013 10:30 am
RCCUMMINS89 wrote:I had a leak back there when I originally bought the donor truck. It didn't affect starting or idling on my mess, but it would make sense as the injection pump would lose some prime
Think it would affect the mechanical advance?
Postby RCCUMMINS89 » Tue Apr 09, 2013 10:35 am
um..... if it was leaking when it was running, then yes it would definitely have an affect at advance in the upper rpm.... as the fuel required to push on the piston is just leaking out.
Postby ellis93 » Tue Apr 09, 2013 11:05 am
RCCUMMINS89 wrote:um..... if it was leaking when it was running, then yes it would definitely have an affect at advance in the upper rpm.... as the fuel required to push on the piston is just leaking out.
This would probably have my mileage screwed up too then,well.....if it's not achieving full advance.
What I may do it is,just to check it......crank it up,stick 12volts to the ksb solenoid and look for leaks while I hold the throttle about 1500/2k. I should know something then......right?
Postby PToombs » Tue Apr 09, 2013 5:12 pm
Now that we know you have a leak and not sand in your vag...... :lol:
Did you have the timing check plug out? The one between the lines? I ask because I had a leak and thought it was the rear KSB o-ring. Turns out, the timing plug was just loose enough to drip, and running fuel down under the pump, making it look like the o-ring was leaking. I was pissed I pulled and sealed the pump and it still leaked. I wondered why that o-ring looked ok..... :roll:
Postby RCCUMMINS89 » Tue Apr 09, 2013 5:15 pm
:lol: :lol: :lol:
Postby oldestof11 » Tue Apr 09, 2013 5:26 pm
Mine did have some idle issues but i thought it was from 10°F and only 1 grid heater working. Also a cold block. mileage was down slightly until it blew. Lost a 1/4 tank in 12 miles.
Postby ellis93 » Tue Apr 09, 2013 6:43 pm
Mr Pete I've never had that plug out :lol: and no sand
Found it Image
Had the appropriate oring in the piece of Kit I had so all is well and I'll get it put back on the truck in the morning.
Postby RCCUMMINS89 » Tue Apr 09, 2013 6:47 pm
I hope this was actually causing issues.... on my truck it wasn't, it just leaked a gallon a minute.
Postby oldestof11 » Tue Apr 09, 2013 6:47 pm
Good deal!
Postby ellis93 » Tue Apr 09, 2013 7:08 pm
RCCUMMINS89 wrote:I hope this was actually causing issues.... on my truck it wasn't, it just leaked a gallon a minute.
It's gotta get better.....something. I'm out of thoughts,even questions on this mofo :lol:
Postby Tacoclaw » Tue Apr 09, 2013 7:52 pm
:mrgreen:
Postby ellis93 » Wed Apr 10, 2013 2:57 am
Nice 8) sweet release :lol:
