RCCUMMINS89 wrote:Mine will keep up with 8ish psi with my set up that made 414..... I put in 24lpm larger injectors and it still holds 6psi. They do surprisingly well.
Tacoclaw wrote:A piston pump, larger diameter supply line from the tank to the IP(including drilling out the banjo bolts or completely bypassing them), and an upgraded fuel filter would probably be able to feed up to 350-400 HP.
I don't know that it could supply it for an extended period of time but I would think you'd overwhelm the cooling system or turbo before fuel starvation became a concern.
