operation rebuild!
both inside and out
Re: operation rebuild!
Postby 93oneton » Sun Apr 28, 2013 7:01 pm
Got the leaf spring perches moved today, also got new wheel studs installed. Hope to get it under the truck tomorrow.
Shit happens
93oneton
Postby Black93 » Mon Apr 29, 2013 6:07 am
Did you get the ubolt plates for the 80?
Truck is looking good.
Black93
Postby 93oneton » Mon Apr 29, 2013 6:10 am
Black93 wrote:Did you get the ubolt plates for the 80?
Ya, I got a set from a buddy. Thanks!
Shit happens
93oneton
Postby 93oneton » Mon Apr 29, 2013 9:20 pm
Got the old girl back tonight from the frame shop. Looks really good. Also got the new springs and the new rear end installed sits a little high in the rear but it should settle over time.
Shit happens
93oneton
Postby 93oneton » Tue Apr 30, 2013 8:20 pm
Got all the holes filled from the old body molding. One more spot to fix from the accident then its off to the paint booth! Can't wait, getting closer.
Shit happens
93oneton
Postby 1STGENFARMBOY » Fri May 03, 2013 5:25 am
fine lookin dog ya got there.
Postby 93oneton » Fri May 03, 2013 5:56 am
1STGENFARMBOY wrote:fine lookin dog ya got there.
Haha thanks, he thinks he's a big help
Shit happens
93oneton
Postby PToombs » Fri May 03, 2013 5:29 pm
I think he's pissed about the new springs, he sure doesn't look too happy about jumping down! :lol:
Postby 93oneton » Sun May 05, 2013 5:57 pm
Well I've been sanding all weekend and got the bed fenders and tail gait almost done. Just need to spray the break through spots with a light coat of primer then one mor time over the entire thing with 600 wet paper then on to the cab!
Shit happens
93oneton
Postby 93oneton » Mon May 06, 2013 8:41 pm
Got the final wet sanding done on the box, fenders, and tail gate. It has a few small spots that need a little more attention. But nothin major.
From the rear it looks like its still a little bent, but I'm not sure cause the ground wasn't really level.
Also got the dent under the cab fixed, looks way better now
Befor
After
Still have to cut in the cab joint in the spot I fixed today, but I'll knock that out tomorrow.
Shit happens
93oneton
Postby 93oneton » Tue May 07, 2013 8:14 pm
Did a little more on the dodge tonight. There was a dent on the roof above the cargo light, it has been there since I bought it. Thought I'd try and smooth it out.
Shit happens
93oneton
Postby 93oneton » Mon May 13, 2013 7:56 pm
Well got the oil girl in the paint shop tonight. Pulled the box, door handles, rear window, windshield. Didn't really plan on pulling it down that far . But the better the prep the better the finish product.
Shit happens
93oneton
Postby 93oneton » Wed May 15, 2013 9:41 pm
Got the truck all taped up and ready primer tomorrow
Shit happens
93oneton
Postby 1STGENFARMBOY » Thu May 16, 2013 11:14 am
when you start shooting color make sure you lay some lights on the floor, I hate getting done and backing it out in the sun and
seeing thin spots down low.
Postby dazedandconfused » Thu May 16, 2013 11:21 am
Are you going back white?
Return to Body
