I have a Borg Warner S357
Postby The_Head » Wed May 01, 2013 2:38 pm
Can I get a bigger compressor wheel for it like you can for the H1C? I'd like to go 60mm. I think there's a gap in between when my S357 dies and the HT3B comes on, so I am willing to give up a little low end spool to help fix it.
I don't have the part number for the turbo, but I can get it if that helps
The_Head
Re: I have a Borg Warner S357
Postby SuperiorRam » Wed May 01, 2013 3:10 pm
That charger is actually a s200 frame 57 is as big as it will handle according to Chris at ED when we had that conversation s300 frames start at 60
92 Cummins: DD, basic mods, topper, 9'2" bossV
92 Cummins: 10' tall, Rockwells and r1's "Dirty Addiction",
83 RC/SB Cummins: engine set back 18", block 89w/h20 after cooler, fire ringed and worked head, studs, billet 64/68/14w/race cover, custom header, bigger sticks, 47rh, dana 60, four wheel disk, and big Mickey Thompsons w/ Weld drag lites. "The Mustard Bucket"
SuperiorRam
Postby RCCUMMINS89 » Wed May 01, 2013 4:39 pm
The s300g can't be upgraded like the "regular" s300
Postby Tacoclaw » Wed May 01, 2013 4:46 pm
Aaaaaaactually, it can. From my (Still unfinished) dealings I've been told that the D-tech turbos are S300g's with bigger wheels stuffed in them. That's why their such a PITA to get housings and stuff for.
That being the case, I doubt those cats are going to be letting wheels and housings go, if you can even find anything about their actual company to inquire.
Postby RCCUMMINS89 » Wed May 01, 2013 4:55 pm
You have MY interest in the above.
Postby Tacoclaw » Wed May 01, 2013 5:02 pm
As I said, my sthi still isn't back or anything, but I know for a fact that those D-tech's cartridges are too small for a normal S300 housing and that dude got me one, it was just a mm or so too small for the inducer.
What sort of parts lead those D-tech cats have with Borg I can't say, but that dude got that housing from Borg and had it punched out for my wheel.
Postby oldestof11 » Wed May 01, 2013 5:45 pm
Jkidd was trying to sell a 62mm wheel in a 200 frame. It was here that it wad mentioned. I think the title was something about interest in a better turbo. About 2 months ago
Postby RCCUMMINS89 » Wed May 01, 2013 8:32 pm
IIRC that was a 59? I think a 59/61/.7?
Postby tampabayBill » Thu May 02, 2013 6:31 am
Check with High Tech. Turbo.
Twins coming soon!
tampabayBill
Postby The_Head » Fri May 03, 2013 3:37 pm
Thanks for the info fellas.
The_Head
Postby danc » Fri May 03, 2013 5:13 pm
HTT turbo has a 60mm comp. wheel and cover for $460. http://htturbo.miiduu.com/Dodge/Turbo-C ... or-Upgrade
1993 club cab 2wd, auto,s300,5x14s,BHAF,powertrax,denny t, Carter 100gph,specrite tc, built 518,tampered pump,and a new headliner.
danc
Postby Tacoclaw » Fri May 03, 2013 5:35 pm
Any chance in loosening your wastegate to get drive to the 3B sooner?
Postby RCCUMMINS89 » Fri May 03, 2013 7:00 pm
Yep.......... that problem is usually because of the exhaust side of things.
Postby RCCUMMINS89 » Sat May 04, 2013 6:47 pm
danc wrote:HTT turbo has a 60mm comp. wheel and cover for $460. http://htturbo.miiduu.com/Dodge/Turbo-C ... or-Upgrade
That makes it a 60/65/14 w/g turbo 8)
Postby AHineman » Sat May 04, 2013 7:20 pm
I wonder how much more it flows...
