Stock injectors
Stock injectors
Postby Nitrous05 » Wed May 15, 2013 4:26 am
Where is the best place to get stock injectors for my 90? I'm having a hard time locating any
Nitrous05
Re: Stock injectors
Postby RCCUMMINS89 » Wed May 15, 2013 6:36 am
I don't know if Bosch still makes them or not.
You can however get some 5x12 155 angle with the 9mm shank for $350
Re: Stock injectors
Postby Nitrous05 » Wed May 15, 2013 10:40 am
I have the 9492's right now, I don't like them... Too smoky. I want to find stock or as close to stock as possible. Thanks
Nitrous05
Re: Stock injectors
Postby RCCUMMINS89 » Wed May 15, 2013 10:52 am
5x12s are going to be as close to stock as you can get without actually going with a 4 hole stock injector.
5x12s are actually almost the exact same size.
Re: Stock injectors
Postby jkidd » Thu May 16, 2013 8:28 am
Depending on what 5x.012 you are going with it can be as much as a 20%-25% upgrade if you are using the marine 370. We have one set of rebuilt with marine 370 nozzles and another POD rebuilt for those on the cheap. We also have injectors in 5 hole and 7 hole that are built on aftermarket bodies that do not require a core.
jkidd
Re: Stock injectors
Postby rockbuggy4x4 » Wed May 29, 2013 12:11 pm
jkidd, does your site have 5x.013 injectors?
Jimmy
--> '85 cab w/ '89 engine and trans stock with minor pump tweaks and a flatbed. **soon to get lots of goodies**
--> '95 jimmy not so stock
rockbuggy4x4
Re: Stock injectors
Postby apexfd » Sat Jun 01, 2013 8:54 pm
jkidd wrote:Depending on what 5x.012 you are going with it can be as much as a 20%-25% upgrade if you are using the marine 370. We have one set of rebuilt with marine 370 nozzles and another POD rebuilt for those on the cheap. We also have injectors in 5 hole and 7 hole that are built on aftermarket bodies that do not require a core.
I had a look at your site earlier today, do you stock any 155 degree injectors??
apexfd
