DTanklage wrote:fluid is good (and level is correct?)
next i would bypass the controller - hot wire to a switch and see what happens
don
also, you know you can not activate the unit until you have sufficient drive shaft speed, right?
pps - if you want to sell the unit, let me know. i need another one. got a buddy that rebuilds them too if you need his info
flashgordon wrote:
is it 4WD,.....if so don't remove the controller, you could brake all kinds of things if it got applied while you were in 4WD.
Flash
