Some head questions
Postby cummins king » Mon Jan 14, 2008 9:46 pm
well? um? it came from some were just not there lol, got a lot on my mine
but im going to call them tomorrow and see what they say
93 4X4 auto
cummins king
Postby Underpsi » Mon Jan 14, 2008 10:05 pm
Seems pretty pointless if you ask me. When you take of your head your suppose to have the head decked anyways so having a head o-ringed only cost like an extra $300 and you won't have to worry about taking boost over 50psi. I don't see why you guys want to spend more money to avoid o-ringing. ALMOST any machine shop can put the grooves in your head, all they need is a new gasket. Unless they have no idea what their doing and then I wouldn't consider them a machine shop... just a shop with machines.
Underpsi
Postby DTanklage » Tue Jan 15, 2008 3:37 am
ford69557ci wrote:
according to thier services site it says you have to cut grooves in the head or block but in the product descrip it says no grooves need to be cut???? anyone know about this setup?
only what i have read. they look just like cometic 'power rings', cept theirs are steel instead of copper. power rings do not req any groove, and from what i read neither do these, if you run the .105 rings. then they have .118 for if you have the head grooved for a o-ring (but are gonna run fire ring instead, no wire) and 125 for if you have a receiver groove in the block and used to have o-ring in the head - least thats how i read it
a grand for the good studs and a gskt
its kinda like the $490 turbo's they are selling for almost 1500 bucks if you ask me
i am really temped to use a solid copper gskt o-rings and reg studs
i know how to put that together so it wont as much as seep on intial start up (yes, before retorque) but dont know about 20k miles later and all those heat cycles
too many choices
cant sleep
lol
DTanklage
Postby CAJUN 93 » Tue Jan 15, 2008 7:12 am
cummins king wrote:curt haslys truck reved 7500rpm after the front dif lock up, and the back end came off the ground while pulling and it didnt blow up, they must be doin somthing right
i was in the stands when that happened right in front of me in houston. i've never heard a diesel engine sound that way (although it didnt stay there for long). the most amazing thing was how HARD the sled hit the back of the truck :shock: . had to scare the hell out of the old guy.
daryl
CAJUN 93
Postby cummins king » Tue Jan 15, 2008 4:38 pm
really that would of been so cool to watch any video's i should check utube
93 4X4 auto
cummins king
Postby ford69557ci » Tue Jan 15, 2008 4:44 pm
i will be runnig a 66-71s300 an a s485 so im gonna be runnin alot of boost. I agree don on the copper gasket i think im just goin to oring the block have reciever grooves cut in the head and run a cooper gasket from flatout with my 14mm studs if the blows then there is no cure lol
ford69557ci
Postby DTanklage » Tue Jan 15, 2008 6:46 pm
call me when you go to install it
i got tricks
DTanklage
Postby ford69557ci » Tue Jan 15, 2008 8:20 pm
will do
ford69557ci
Users browsing this forum: No registered users and 99 guests
