HOMEMADE 4" DOWNPIPE
Postby 92 D/UNIT » Wed Jan 17, 2007 10:13 pm
not the pretiest but it works, word of advice, if you got the money buy one pre made, its pretty time consuming :lol:
388/886
92 D/UNIT
Postby sdstriper » Thu Jan 18, 2007 11:36 am
Brian where's your pyro probe installed at?
sdstriper
Postby Greenleaf » Thu Jan 18, 2007 12:49 pm
I make exhaust systems regular like, for the fleet of buses. When I made my 4inch DP, it took some time. Yesteday I finished up a 3.5 inch DP with out the truck on hand, so I used the original broken DP and it turned out fine. I'd have to say the 3.5 inch looks better when installed on our trucks.. The four inch pipe I made and installed looks like a three year old wearing size 12 shoes. A turbo with four inch outlet would be more appropriate looking/application. Not one with 2.75 inch outlet.
Greenleaf
tech specialist/mod
Postby sdstriper » Thu Jan 18, 2007 1:33 pm
I'll try and post a pic of the 16cm2 Onan housing with the bolt on exhaust adapter. I have a sweet straight to 4" adapter on it. We'll see if the Puter challenged kid can get you a pic...
sdstriper
Postby PToombs » Thu Jan 18, 2007 5:14 pm
I made my pipe, the weld where you can see it is nasty. Of course, the one down underneath is perfect! :roll: I'll see if I can get some pics. When I got done, I realized that I had an extra inch to play with. It would have made it look nicer on the bend. :wink:
It only took me about an hour, from turbo to back of cab. I did steal the chopsaw from work though! :)
Postby 92 D/UNIT » Thu Jan 18, 2007 7:31 pm
sdstriper wrote:Brian where's your pyro probe installed at?
pre turbo
388/886
92 D/UNIT
Postby 92 D/UNIT » Thu Jan 18, 2007 7:33 pm
i agree with you Greenleaf. looks like a three year old wearing size 12 shoes. :lol:
388/886
92 D/UNIT
Postby PToombs » Fri Jan 19, 2007 4:43 pm
I don't care what size shoes he wears, as long as he's a fast mothertrucker!
It's nice if it looks pretty, but function 1st, form 2nd. :idea: We were still talkin' trucks, right? :wink:
Postby NukleusX » Fri Jan 19, 2007 5:15 pm
I dont have plans to make my own 4" DP (dont have equipment) but when I order one, i can either have it sent to me with an adapter on it, or order one from another company? I am kinda confused, but I am planning on doing this sooner than later so it'd be good to know.
--Jeremy--
1990 D350 SC, LB, DRW Straight piped, K&N Air, DiPricol Boost & Pyro, Pump Tweaked, Gear Vendors OD - adding injectors, turbo, built tranny, 5"stack soon
NukleusX
Postby Fred S » Tue Jan 30, 2007 9:53 pm
Rip's 4" DP comes bare, you put the adapter of choice. he sells those too.
92 W250 LB Crewcab 3" Alcans, NV5600 4x4, 35inch Toyo ATs, some tweaks
2001 Golf TDI TDTuning-Stg4, R520s, SBC, 17/22
94 Toyota Ex-Cab 4x4 (01 ALH(TDI)) TDTuning-Stg4, PP764s, SBC, 17/22
Fred S
Postby JD730 » Sat Apr 07, 2007 7:31 am
Fred S wrote:Rip's 4" DP comes bare, you put the adapter of choice. he sells those too.
Just installed one with a HX40 flange for my HTB2, fits tight, but doesn't hit anything. Had to trim 5/8" off it to make it fit a little better.
Mike
The "Rattle Box"
JD730
Postby Jeep-hauler » Tue Jan 15, 2008 6:22 pm
This is sort of an old thread, but I recently built my own down-pipe. While driving home last week, my truck suddenly got louder. Turns out the down pipe broke at the 90* bend just after the turbo. The truck already had a nice mandrel bent 4" system that started under the firewall, so this was a good excuse to go 4" all the way. I bought a short radius 90, a long radius 90, a 45 pipe section, and a clamp from the local truck shop. Cost about $70. I cut out the 3x4" reducer under the cab, and used it at the turbo outlet. Worked out pretty good.
-Jeremy
'51 Power Wagon VE Cummins project.
'92 W250 -Got it cheap, it runs, it's ugly, it's a parts truck
'93 W250 -tweaked pump, 4" exhaust, NV 4500HD 5-speed. Jeep tow rig, daily driver. Sold.
Jeep-hauler
Postby cummins king » Tue Jan 15, 2008 6:43 pm
hey that looks good i hope my 5 inch dp looks that good
93 4X4 auto
cummins king
Postby greasemonkey » Tue Jan 15, 2008 9:21 pm
Jeremy, that looks good!
to me that looks ridiculously easy, well, at least way less work than I figured it'd be. I haven't climbed around the exhaust side of my truck a whole lot, yet.
but I do fabricate 3" stainless plumbing for the spray systems on these ag aircraft, so that downpipe doesn't look like much work at all. add one more thing to the list of NECESSARY mods for my truck!
'93 250 4x4 NV4500, flatbed, club cab, ex brake, pump tweaked, too many new ideas thanks to you guys.
dubbed the "Mexican Mtn Goat"
..if you find yourself in a fair fight you did not properly prepare..
..hot rodders are the original recyclers!..
greasemonkey
Postby PToombs » Wed Jan 16, 2008 5:57 pm
That looks good! The new pipe looks 3 inches bigger than the stocker! :shock:
Return to Cool projects YOU can do
